Home » Eclipse Projects » Sirius » multiple diagram elements for the same domain class
multiple diagram elements for the same domain class [message #1801632] Thu, 24 January 2019 00:03 Go to next message
PETROS SOURSOS is currently offline PETROS SOURSOSFriend
Hello!
Is it possible to have multiple diagram elements for the same domain class?
I have a domain class that I want to represent as a node or container depending
on the type of some attribute. But when I create the node, for example, a container is created automatically.
Thank you.
Re: multiple diagram elements for the same domain class [message #1801683 is a reply to message #1801632] Thu, 24 January 2019 16:49 Go to previous message
Julien Dupont is currently offline Julien DupontFriend
Yes it's possible and you must define a Precondition Expression in the advanced tab, or filter in the Semantic Candidates expression if you can in your case.
In your case if I understand correctly your need you can do a ->select(a | a.haveChildren = false) for the nodes and ->select(a | a.haveChildren) for the containers. In this case you have a node if this element doesn't have children and a container otherwise.
Previous Topic:getting resource malformed URL exception while loading the model
Next Topic:How to auto create unique identifier for instances?
Current Time: Tue Mar 02 05:41:21 GMT 2021
Powered by FUDForum. Page generated in 0.02063 seconds
