Home » Archived » Orion (Archived) » Orion WAR does not work
Orion WAR does not work [message #1801423] Fri, 18 January 2019 19:27 Go to next message
Pablo  eltrán is currently offline Pablo eltránFriend
I followed these instructions
https://wiki.eclipse.org/Orion/Releng_Builds#WAR_for_Apache_Tomcat
to build the WAR file for Orion R19. The build process works fine, so I was able to build and deploy Orion on a Tomcat (8.0-Window) form my Eclipse IDE.
The Orion Server looks like starting. However, I get a blank page and the error below in the Eclipse logs. Some packages reamain in STARTING state and they never become fully STARTED.
Might you help?
Thanks in advance,
Pablo.
===============Errror in Eclipse's log ==============
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:67)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:147)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4594)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:215)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:64)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:204)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:199)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:138)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:81)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:42)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.impl.StringToObjectMapImpl.setTypedValue(StringToObjectMapImpl.java:136)
at org.eclipse.e4.ui.model.application.impl.StringToObjectMapImpl.setValue(StringToObjectMapImpl.java:288)
at org.eclipse.emf.common.util.BasicEMap.putEntry(BasicEMap.java:297)
at org.eclipse.emf.common.util.BasicEMap.put(BasicEMap.java:578)
at org.eclipse.emf.common.util.BasicEMap$DelegatingMap.put(BasicEMap.java:793)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:773)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:684)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:97)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.lambda$0(ContributedPartRenderer.java:63)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4145)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1517)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2347)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4812)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2162)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4792)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2304)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:91)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4867)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1470)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5872)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2203)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1562)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5971)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:2793)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3556)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:628)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.e4.ui.workbench.addons.minmax.TrimStack.handleTransientDataEvents(TrimStack.java:228)
at sun.reflect.GeneratedMethodAccessor38.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 118 more
========Orion Server's output ===================
Jan 18, 2019 8:02:53 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version: Apache Tomcat/8.0.36
INFO: Server built: Jun 9 2016 13:55:50 UTC
INFO: Server number: 8.0.36.0
INFO: OS Name: Windows 10
INFO: OS Version: 10.0
INFO: Architecture: amd64
INFO: Java Home: C:\Program Files\Java\jre1.8.0_181
INFO: JVM Version: 1.8.0_181-b13
INFO: JVM Vendor: Oracle Corporation
INFO: CATALINA_BASE: C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: CATALINA_HOME: C:\Users\pablo\tomcat\8.0.36
INFO: Command line argument: -Dcatalina.base=C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: Command line argument: -Dcatalina.home=C:\Users\pablo\tomcat\8.0.36
INFO: Command line argument: -Dwtp.deploy=C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps
INFO: Command line argument: -Djava.endorsed.dirs=C:\Users\pablo\tomcat\8.0.36\endorsed
INFO: Command line argument: -Dorion.core.configFile=C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf\orion.conf
INFO: Command line argument: -Dfile.encoding=Cp1252
INFO: Command line argument: -Xbootclasspath:C:\Program Files\Java\jdk1.8.0_181\jre\lib\resources.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\rt.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\jce.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\charsets.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\jfr.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\access-bridge-64.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\cldrdata.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\dnsns.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\jaccess.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\jfxrt.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\localedata.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\nashorn.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\sunec.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\sunjce_provider.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\sunmscapi.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\sunpkcs11.jar;C:\Program Files\Java\jdk1.8.0_181\jre\lib\ext\zipfs.jar
Jan 18, 2019 8:02:53 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre1.8.0_181\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre1.8.0_181/bin/server;C:/Program Files/Java/jre1.8.0_181/bin;C:/Program Files/Java/jre1.8.0_181/lib/amd64;C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\oraclexe\app\oracle\product\11.2.0\server\bin;;C:\csvn\bin\;C:\csvn\Python25\;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\apache-maven-3.5.2\bin;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\AutoFirma\AutoFirma;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\ManagementStudio\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\MySQL\MySQL Utilities 1.6\;C:\Program Files\Amazon\AWSCLI\bin\;C:\Users\pablo\AppData\Local\Microsoft\WindowsApps;;C:\Applications\Atlassian\atlassian-plugin-sdk-6.3.6\bin;C:\WINDOWS\system32;;.
Jan 18, 2019 8:02:53 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-9090"]
Jan 18, 2019 8:02:53 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
INFO: Using a shared selector for servlet write/read
INFO: Initializing ProtocolHandler ["ajp-nio-9009"]
Jan 18, 2019 8:02:53 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 764 ms
Jan 18, 2019 8:02:53 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Jan 18, 2019 8:02:53 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/8.0.36
Jan 18, 2019 8:02:54 PM org.apache.jasper.servlet.TldScanner scanJars
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Jan 18, 2019 8:02:54 PM org.apache.catalina.core.ApplicationContext log
INFO: Bridge Servlet _contextPreloads (com.ibm.websphere.ssl.protocol.SSLSocketFactory) com.ibm.websphere.ssl.protocol.SSLSocketFactory
INFO: Bridge Servlet _initSSLSocketFactory - start
INFO: Bridge Servlet _initSSLSocketFactory - succesful
Jan 18, 2019 8:02:55 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-9090"]
INFO: Starting ProtocolHandler ["ajp-nio-9009"]
Jan 18, 2019 8:02:55 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1268 ms
osgi> 20:03:01,741 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.groovy]
20:03:01,741 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
20:03:01,741 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [logback.xml] at [bundleresource://2.fwk1724096178:1/logback.xml]
20:03:01,748 |-INFO in ch.qos.logback.core.joran.spi.ConfigurationWatchList@215576c3 - URL [bundleresource://2.fwk1724096178:1/logback.xml] is not of type file
20:03:01,767 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - debug attribute not set
20:03:01,768 |-INFO in ch.qos.logback.classic.joran.action.LoggerContextListenerAction - Adding LoggerContextListener of type [ch.qos.logback.classic.jul.LevelChangePropagator] to the object stack
20:03:01,780 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating DEBUG level on Logger[ROOT] onto the JUL framework
20:03:01,780 |-INFO in ch.qos.logback.classic.joran.action.LoggerContextListenerAction - Starting LoggerContextListener
20:03:01,780 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
20:03:01,782 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [STDOUT]
20:03:01,805 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - This appender no longer admits a layout as a sub-component, set an encoder instead.
20:03:01,805 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - To ensure compatibility, wrapping your layout in LayoutWrappingEncoder.
20:03:01,805 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - See also http://logback.qos.ch/codes.html#layoutInsteadOfEncoder for details
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.internal.server.search.Indexer] to INFO
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating INFO level on Logger[org.eclipse.orion.internal.server.search.Indexer] onto the JUL framework
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.login] to INFO
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating INFO level on Logger[org.eclipse.orion.server.login] onto the JUL framework
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.account] to INFO
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating INFO level on Logger[org.eclipse.orion.server.account] onto the JUL framework
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.core] to WARN
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating WARN level on Logger[org.eclipse.orion.server.core] onto the JUL framework
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.config] to INFO
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating INFO level on Logger[org.eclipse.orion.server.config] onto the JUL framework
20:03:01,806 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to WARN
20:03:01,806 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@1c79bf9a - Propagating WARN level on Logger[ROOT] onto the JUL framework
20:03:01,807 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [STDOUT] to Logger[ROOT]
20:03:01,807 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
20:03:01,808 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@2ff44f58 - Registering current configuration as safe fallback point
[2019-01-18 19:03:01.840 Z] [http-nio-9090-exec-2] INFO org.eclipse.orion.server.config - Server configuration file loaded from: C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf\orion.conf
[2019-01-18 19:03:01.866 Z] [http-nio-9090-exec-2] INFO org.eclipse.orion.server.config - Loaded simple metadata store (version 8).
[2019-01-18 19:03:01.872 Z] [http-nio-9090-exec-2] INFO org.eclipse.orion.server.config - Tasks metadata location is C:\Users\pablo\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\work\Catalina\localhost\code\eclipse\workspace\.metadata\.tasks
[2019-01-18 19:03:01.888 Z] [http-nio-9090-exec-2] INFO org.eclipse.orion.server.config - Started Orion server core successfully.
[2019-01-18 19:03:01.894 Z] [http-nio-9090-exec-2] INFO org.eclipse.orion.server.config - Started Orion server authentication successfully.
[2019-01-18 19:03:01.896 Z] [Worker-0] INFO org.eclipse.orion.server.config - Finished processing 0 users for registerUserProperties, duration: 0ms
========== ss command output performed from the console ==============
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.10.0.v20140606-1445
Fragments=81, 111
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203
2 RESOLVED ch.qos.logback.classic_1.0.7.v20121108-1250
Fragments=106
3 RESOLVED ch.qos.logback.core_1.0.7.v20121108-1250
4 RESOLVED ch.qos.logback.slf4j_1.0.7.v201505121915
Master=123
5 STARTING com.google.protobuf_2.4.0.v201105131100
6 STARTING com.ibm.icu_52.1.0.v201404241930
7 RESOLVED com.jcraft.jsch_0.1.53.v201508180515
8 RESOLVED javaewah_0.7.9.v201605172130
9 RESOLVED javax.activation_1.1.0.v201211130549
10 RESOLVED javax.annotation_1.2.0.v201401042248
11 RESOLVED javax.inject_1.0.0.v20091030
12 RESOLVED javax.mail.glassfish_1.4.1.v201108011116
13 RESOLVED javax.servlet_3.0.0.v201112011016
14 RESOLVED javax.xml_1.3.4.v201005080400
15 RESOLVED org.apache.batik.css_1.7.0.v201011041433
16 RESOLVED org.apache.batik.util_1.7.0.v201011041433
17 RESOLVED org.apache.batik.util.gui_1.7.0.v200903091627
18 RESOLVED org.apache.commons.codec_1.6.0.v201305230611
19 RESOLVED org.apache.commons.compress_1.6.0.v201310281400
20 RESOLVED org.apache.commons.httpclient_3.1.0.v201012070820
21 RESOLVED org.apache.commons.io_2.2.0.v201405211200
22 RESOLVED org.apache.commons.logging_1.1.1.v201101211721
23 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
24 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
25 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
26 RESOLVED org.apache.oltu.oauth2.client_1.0.0.v20150306-0038
27 STARTING org.apache.oltu.oauth2.common_1.0.0.v20150306-0038
28 RESOLVED org.apache.xerces_2.9.0.v201101211617
29 RESOLVED org.apache.xml.resolver_1.2.0.v201005080400
30 RESOLVED org.apache.xml.serializer_2.7.1.v201005080400
31 STARTING org.eclipse.compare.core_3.5.400.v20130903-0736
32 RESOLVED org.eclipse.core.commands_3.6.100.v20140528-1422
33 STARTING org.eclipse.core.contenttype_3.4.200.v20140207-1251
34 STARTING org.eclipse.core.databinding_1.4.1.v20140214-0004
35 RESOLVED org.eclipse.core.databinding.beans_1.2.200.v20140214-0004
36 STARTING org.eclipse.core.databinding.observable_1.4.1.v20140210-1835
37 STARTING org.eclipse.core.databinding.property_1.4.200.v20140214-0004
38 STARTING org.eclipse.core.expressions_3.4.600.v20140128-0851
39 ACTIVE org.eclipse.core.filesystem_1.4.100.v20140514-1614
Fragments=40
40 RESOLVED org.eclipse.core.filesystem.win32.x86_64_1.4.0.v20140124-1940
Master=39
41 ACTIVE org.eclipse.core.jobs_3.6.0.v20140424-0053
42 STARTING org.eclipse.core.runtime_3.10.0.v20140318-2214
43 STARTING org.eclipse.core.variables_3.2.800.v20130819-1716
44 STARTING org.eclipse.e4.core.commands_0.10.2.v20140424-2344
45 STARTING org.eclipse.e4.core.contexts_1.3.100.v20140407-1019
46 STARTING org.eclipse.e4.core.di_1.4.0.v20140414-1837
47 STARTING org.eclipse.e4.core.di.extensions_0.12.0.v20140417-2033
48 STARTING org.eclipse.e4.core.services_1.2.0.v20140509-1840
49 STARTING org.eclipse.e4.ui.bindings_0.10.200.v20140424-2042
50 RESOLVED org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042
51 STARTING org.eclipse.e4.ui.css.swt_0.11.100.v20140522-1045
52 STARTING org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042
53 STARTING org.eclipse.e4.ui.di_1.0.0.v20140328-2112
54 STARTING org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820
55 STARTING org.eclipse.e4.ui.services_1.1.0.v20140328-1925
56 RESOLVED org.eclipse.e4.ui.widgets_1.0.0.v20140514-1823
57 STARTING org.eclipse.e4.ui.workbench_1.1.0.v20140528-1949
58 STARTING org.eclipse.e4.ui.workbench.addons.swt_1.1.0.v20140602-1537
59 STARTING org.eclipse.e4.ui.workbench.renderers.swt_0.12.0.v20140521-1818
60 STARTING org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436
61 RESOLVED org.eclipse.e4.ui.workbench3_0.12.0.v20140227-2118
62 STARTING org.eclipse.emf.common_2.9.2.v20131212-0545
63 STARTING org.eclipse.emf.ecore_2.9.2.v20131212-0545
64 STARTING org.eclipse.emf.ecore.change_2.9.0.v20131212-0545
65 STARTING org.eclipse.emf.ecore.xmi_2.9.1.v20131212-0545
66 STARTING org.eclipse.equinox.app_1.3.200.v20130910-1609
67 STARTING org.eclipse.equinox.bidi_0.10.0.v20130327-1442
68 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
69 ACTIVE org.eclipse.equinox.console_1.1.0.v20140131-1639
70 ACTIVE org.eclipse.equinox.ds_1.4.200.v20131126-2331
71 ACTIVE org.eclipse.equinox.event_1.3.100.v20140115-1647
72 STARTING org.eclipse.equinox.http.jetty_3.0.200.v20131021-1843
Fragments=105
73 ACTIVE org.eclipse.equinox.http.registry_1.1.300.v20130402-1529
74 ACTIVE org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755
75 ACTIVE org.eclipse.equinox.http.servletbridge_1.1.100.201901181935
76 RESOLVED org.eclipse.equinox.launcher_1.3.0.v20140415-2008
Fragments=77
77 RESOLVED org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140603-1326
Master=76
78 ACTIVE org.eclipse.equinox.preferences_3.5.200.v20140224-1527
79 ACTIVE org.eclipse.equinox.registry_3.5.400.v20140428-1507
80 STARTING org.eclipse.equinox.security_1.2.0.v20130424-1801
81 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.3.100.201901181935
Master=0
82 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
83 STARTING org.eclipse.help_3.6.0.v20130326-1254
84 RESOLVED org.eclipse.jetty.client_8.1.15.v20140411
85 RESOLVED org.eclipse.jetty.continuation_8.1.15.v20140411
86 RESOLVED org.eclipse.jetty.http_8.1.15.v20140411
87 RESOLVED org.eclipse.jetty.io_8.1.15.v20140411
88 RESOLVED org.eclipse.jetty.security_8.1.15.v20140411
89 RESOLVED org.eclipse.jetty.server_8.1.15.v20140411
90 RESOLVED org.eclipse.jetty.servlet_8.1.15.v20140411
91 RESOLVED org.eclipse.jetty.servlets_8.1.15.v20140411
92 RESOLVED org.eclipse.jetty.util_8.1.15.v20140411
93 RESOLVED org.eclipse.jetty9.websocket_1.0.0.v20141001-1004
94 STARTING org.eclipse.jface_3.10.0.v20140604-0740
95 RESOLVED org.eclipse.jface.databinding_1.6.200.v20140528-1422
96 RESOLVED org.eclipse.jface.text_3.9.0.v20140521-1657
97 STARTING org.eclipse.jgit_4.4.0.201606070830-r
98 STARTING org.eclipse.orion.client.debug_1.0.0.v20190117-1659
99 ACTIVE org.eclipse.orion.server.authentication_1.0.0.v20170601-2114
100 STARTING org.eclipse.orion.server.cf_1.0.0.v20171116-1531
101 ACTIVE org.eclipse.orion.server.core_1.0.0.v20171117-2131
102 STARTING org.eclipse.orion.server.git_1.0.0.v20171005-2125
103 ACTIVE org.eclipse.orion.server.hosting_1.0.0.v20150513-1949
104 STARTING org.eclipse.orion.server.jetty_1.0.0.v20150306-0038
105 RESOLVED org.eclipse.orion.server.jettycustomizer_1.0.0.v20150306-0038
Master=72
106 RESOLVED org.eclipse.orion.server.logback.config_1.0.0.v20160624-1719
Master=2
107 STARTING org.eclipse.orion.server.logs_1.0.0.v20170427-1925
108 STARTING org.eclipse.orion.server.search_1.0.0.v20170427-1540
109 ACTIVE org.eclipse.orion.server.servlets_1.0.0.v20170918-2114
110 STARTING org.eclipse.orion.server.ui_1.0.0.v20150306-0038
111 RESOLVED org.eclipse.osgi.compatibility.state_1.0.0.v20140403-1907
Master=0
112 RESOLVED org.eclipse.osgi.services_3.4.0.v20140312-2051
113 STARTING org.eclipse.rcp_4.3.100.v20140606-1215
114 RESOLVED org.eclipse.swt_3.103.0.v20140605-2008
Fragments=115
115 RESOLVED org.eclipse.swt.win32.win32.x86_64_3.103.0.v20140605-2012
Master=114
116 RESOLVED org.eclipse.text_3.5.300.v20130515-1451
117 STARTING org.eclipse.ui_3.106.0.v20140519-0906
118 STARTING org.eclipse.ui.console_3.5.300.v20140424-1437
119 STARTING org.eclipse.ui.workbench_3.106.0.v20140530-0732
120 STARTING org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521
121 STARTING org.eclipse.update.configurator_3.3.300.v20140518-1928
122 RESOLVED org.json_1.0.0.v201011060100
123 RESOLVED org.slf4j.api_1.7.2.v20121108-1250
Fragments=4
124 RESOLVED org.slf4j.jcl_1.7.2.v20130115-1340
125 RESOLVED org.slf4j.jul_1.7.2.v20121108-1250
126 RESOLVED org.slf4j.log4j_1.7.2.v20130115-1340
127 RESOLVED org.w3c.css.sac_1.3.1.v200903091627
128 RESOLVED org.w3c.dom.events_3.0.0.draft20060413_v201105210656
129 RESOLVED org.w3c.dom.smil_1.0.0.v200806040011
130 RESOLVED org.w3c.dom.svg_1.1.0.v201011041433
131 RESOLVED org.yaml.snakeyaml_1.14.0.v20150421-1508
============= bundles.info==============
#encoding=UTF-8
#version=1
ch.qos.logback.classic,1.0.7.v20121108-1250,plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar,4,false
ch.qos.logback.core,1.0.7.v20121108-1250,plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar,4,false
ch.qos.logback.slf4j,1.0.7.v201505121915,plugins/ch.qos.logback.slf4j_1.0.7.v201505121915.jar,4,false
com.google.protobuf,2.4.0.v201105131100,plugins/com.google.protobuf_2.4.0.v201105131100.jar,4,false
com.ibm.icu,52.1.0.v201404241930,plugins/com.ibm.icu_52.1.0.v201404241930.jar,4,false
com.jcraft.jsch,0.1.53.v201508180515,plugins/com.jcraft.jsch_0.1.53.v201508180515.jar,4,false
javaewah,0.7.9.v201605172130,plugins/javaewah_0.7.9.v201605172130.jar,4,false
javax.activation,1.1.0.v201211130549,plugins/javax.activation_1.1.0.v201211130549.jar,4,false
javax.annotation,1.2.0.v201401042248,plugins/javax.annotation_1.2.0.v201401042248.jar,4,false
javax.inject,1.0.0.v20091030,plugins/javax.inject_1.0.0.v20091030.jar,4,false
javax.mail.glassfish,1.4.1.v201108011116,plugins/javax.mail.glassfish_1.4.1.v201108011116.jar,4,false
javax.servlet,3.0.0.v201112011016,plugins/javax.servlet_3.0.0.v201112011016.jar,4,false
javax.xml,1.3.4.v201005080400,plugins/javax.xml_1.3.4.v201005080400.jar,4,false
org.apache.batik.css,1.7.0.v201011041433,plugins/org.apache.batik.css_1.7.0.v201011041433.jar,4,false
org.apache.batik.util,1.7.0.v201011041433,plugins/org.apache.batik.util_1.7.0.v201011041433.jar,4,false
org.apache.batik.util.gui,1.7.0.v200903091627,plugins/org.apache.batik.util.gui_1.7.0.v200903091627.jar,4,false
org.apache.commons.codec,1.6.0.v201305230611,plugins/org.apache.commons.codec_1.6.0.v201305230611.jar,4,false
org.apache.commons.compress,1.6.0.v201310281400,plugins/org.apache.commons.compress_1.6.0.v201310281400.jar,4,false
org.apache.commons.httpclient,3.1.0.v201012070820,plugins/org.apache.commons.httpclient_3.1.0.v201012070820.jar,4,false
org.apache.commons.io,2.2.0.v201405211200,plugins/org.apache.commons.io_2.2.0.v201405211200.jar,4,false
org.apache.commons.logging,1.1.1.v201101211721,plugins/org.apache.commons.logging_1.1.1.v201101211721.jar,4,false
org.apache.felix.gogo.command,0.10.0.v201209301215,plugins/org.apache.felix.gogo.command_0.10.0.v201209301215.jar,4,false
org.apache.felix.gogo.runtime,0.10.0.v201209301036,plugins/org.apache.felix.gogo.runtime_0.10.0.v201209301036.jar,4,false
org.apache.felix.gogo.shell,0.10.0.v201212101605,plugins/org.apache.felix.gogo.shell_0.10.0.v201212101605.jar,4,false
org.apache.oltu.oauth2.client,1.0.0.v20150306-0038,plugins/org.apache.oltu.oauth2.client_1.0.0.v20150306-0038.jar,4,false
org.apache.oltu.oauth2.common,1.0.0.v20150306-0038,plugins/org.apache.oltu.oauth2.common_1.0.0.v20150306-0038.jar,4,false
org.apache.xerces,2.9.0.v201101211617,plugins/org.apache.xerces_2.9.0.v201101211617.jar,4,false
org.apache.xml.resolver,1.2.0.v201005080400,plugins/org.apache.xml.resolver_1.2.0.v201005080400.jar,4,false
org.apache.xml.serializer,2.7.1.v201005080400,plugins/org.apache.xml.serializer_2.7.1.v201005080400.jar,4,false
org.cyberneko.html,1.9.14.v201105210654,plugins/org.cyberneko.html_1.9.14.v201105210654,4,false
org.eclipse.compare.core,3.5.400.v20130903-0736,plugins/org.eclipse.compare.core_3.5.400.v20130903-0736.jar,4,false
org.eclipse.core.commands,3.6.100.v20140528-1422,plugins/org.eclipse.core.commands_3.6.100.v20140528-1422.jar,4,false
org.eclipse.core.contenttype,3.4.200.v20140207-1251,plugins/org.eclipse.core.contenttype_3.4.200.v20140207-1251.jar,4,false
org.eclipse.core.databinding,1.4.1.v20140214-0004,plugins/org.eclipse.core.databinding_1.4.1.v20140214-0004.jar,4,false
org.eclipse.core.databinding.beans,1.2.200.v20140214-0004,plugins/org.eclipse.core.databinding.beans_1.2.200.v20140214-0004.jar,4,false
org.eclipse.core.databinding.observable,1.4.1.v20140210-1835,plugins/org.eclipse.core.databinding.observable_1.4.1.v20140210-1835.jar,4,false
org.eclipse.core.databinding.property,1.4.200.v20140214-0004,plugins/org.eclipse.core.databinding.property_1.4.200.v20140214-0004.jar,4,false
org.eclipse.core.expressions,3.4.600.v20140128-0851,plugins/org.eclipse.core.expressions_3.4.600.v20140128-0851.jar,4,false
org.eclipse.core.filesystem,1.4.100.v20140514-1614,plugins/org.eclipse.core.filesystem_1.4.100.v20140514-1614.jar,4,false
org.eclipse.core.filesystem.win32.x86_64,1.4.0.v20140124-1940,plugins/org.eclipse.core.filesystem.win32.x86_64_1.4.0.v20140124-1940.jar,4,false
org.eclipse.core.jobs,3.6.0.v20140424-0053,plugins/org.eclipse.core.jobs_3.6.0.v20140424-0053.jar,4,false
org.eclipse.core.runtime,3.10.0.v20140318-2214,plugins/org.eclipse.core.runtime_3.10.0.v20140318-2214.jar,4,false
org.eclipse.core.variables,3.2.800.v20130819-1716,plugins/org.eclipse.core.variables_3.2.800.v20130819-1716.jar,4,false
org.eclipse.e4.core.commands,0.10.2.v20140424-2344,plugins/org.eclipse.e4.core.commands_0.10.2.v20140424-2344.jar,4,false
org.eclipse.e4.core.contexts,1.3.100.v20140407-1019,plugins/org.eclipse.e4.core.contexts_1.3.100.v20140407-1019.jar,4,false
org.eclipse.e4.core.di,1.4.0.v20140414-1837,plugins/org.eclipse.e4.core.di_1.4.0.v20140414-1837.jar,4,false
org.eclipse.e4.core.di.extensions,0.12.0.v20140417-2033,plugins/org.eclipse.e4.core.di.extensions_0.12.0.v20140417-2033.jar,4,false
org.eclipse.e4.core.services,1.2.0.v20140509-1840,plugins/org.eclipse.e4.core.services_1.2.0.v20140509-1840.jar,4,false
org.eclipse.e4.ui.bindings,0.10.200.v20140424-2042,plugins/org.eclipse.e4.ui.bindings_0.10.200.v20140424-2042.jar,4,false
org.eclipse.e4.ui.css.core,0.10.100.v20140424-2042,plugins/org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042.jar,4,false
org.eclipse.e4.ui.css.swt,0.11.100.v20140522-1045,plugins/org.eclipse.e4.ui.css.swt_0.11.100.v20140522-1045.jar,4,false
org.eclipse.e4.ui.css.swt.theme,0.9.300.v20140424-2042,plugins/org.eclipse.e4.ui.css.swt.theme_0.9.300.v20140424-2042.jar,4,false
org.eclipse.e4.ui.di,1.0.0.v20140328-2112,plugins/org.eclipse.e4.ui.di_1.0.0.v20140328-2112.jar,4,false
org.eclipse.e4.ui.model.workbench,1.1.0.v20140512-1820,plugins/org.eclipse.e4.ui.model.workbench_1.1.0.v20140512-1820.jar,4,false
org.eclipse.e4.ui.services,1.1.0.v20140328-1925,plugins/org.eclipse.e4.ui.services_1.1.0.v20140328-1925.jar,4,false
org.eclipse.e4.ui.widgets,1.0.0.v20140514-1823,plugins/org.eclipse.e4.ui.widgets_1.0.0.v20140514-1823.jar,4,false
org.eclipse.e4.ui.workbench,1.1.0.v20140528-1949,plugins/org.eclipse.e4.ui.workbench_1.1.0.v20140528-1949.jar,4,false
org.eclipse.e4.ui.workbench.addons.swt,1.1.0.v20140602-1537,plugins/org.eclipse.e4.ui.workbench.addons.swt_1.1.0.v20140602-1537.jar,4,false
org.eclipse.e4.ui.workbench.renderers.swt,0.12.0.v20140521-1818,plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.12.0.v20140521-1818.jar,4,false
org.eclipse.e4.ui.workbench.swt,0.12.100.v20140530-1436,plugins/org.eclipse.e4.ui.workbench.swt_0.12.100.v20140530-1436.jar,4,false
org.eclipse.e4.ui.workbench3,0.12.0.v20140227-2118,plugins/org.eclipse.e4.ui.workbench3_0.12.0.v20140227-2118.jar,4,false
org.eclipse.emf.common,2.9.2.v20131212-0545,plugins/org.eclipse.emf.common_2.9.2.v20131212-0545.jar,4,false
org.eclipse.emf.ecore,2.9.2.v20131212-0545,plugins/org.eclipse.emf.ecore_2.9.2.v20131212-0545.jar,4,false
org.eclipse.emf.ecore.change,2.9.0.v20131212-0545,plugins/org.eclipse.emf.ecore.change_2.9.0.v20131212-0545.jar,4,false
org.eclipse.emf.ecore.xmi,2.9.1.v20131212-0545,plugins/org.eclipse.emf.ecore.xmi_2.9.1.v20131212-0545.jar,4,false
org.eclipse.equinox.app,1.3.200.v20130910-1609,plugins/org.eclipse.equinox.app_1.3.200.v20130910-1609.jar,4,false
org.eclipse.equinox.bidi,0.10.0.v20130327-1442,plugins/org.eclipse.equinox.bidi_0.10.0.v20130327-1442.jar,4,false
org.eclipse.equinox.common,3.6.200.v20130402-1505,plugins/org.eclipse.equinox.common_3.6.200.v20130402-1505.jar,2,true
org.eclipse.equinox.console,1.1.0.v20140131-1639,plugins/org.eclipse.equinox.console_1.1.0.v20140131-1639.jar,4,false
org.eclipse.equinox.ds,1.4.200.v20131126-2331,plugins/org.eclipse.equinox.ds_1.4.200.v20131126-2331.jar,2,true
org.eclipse.equinox.event,1.3.100.v20140115-1647,plugins/org.eclipse.equinox.event_1.3.100.v20140115-1647.jar,4,false
org.eclipse.equinox.http.jetty,3.0.200.v20131021-1843,plugins/org.eclipse.equinox.http.jetty_3.0.200.v20131021-1843.jar,4,false
org.eclipse.equinox.http.registry,1.1.300.v20130402-1529,plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar,2,true
org.eclipse.equinox.http.servlet,1.1.500.v20140318-1755,plugins/org.eclipse.equinox.http.servlet_1.1.500.v20140318-1755.jar,4,false
org.eclipse.equinox.http.servletbridge,1.1.100.201901181935,plugins/org.eclipse.equinox.http.servletbridge_1.1.100.201901181935.jar,2,true
org.eclipse.equinox.launcher,1.3.0.v20140415-2008,plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar,4,false
org.eclipse.equinox.launcher.win32.win32.x86_64,1.1.200.v20140603-1326,plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20140603-1326,4,false
org.eclipse.equinox.preferences,3.5.200.v20140224-1527,plugins/org.eclipse.equinox.preferences_3.5.200.v20140224-1527.jar,4,false
org.eclipse.equinox.registry,3.5.400.v20140428-1507,plugins/org.eclipse.equinox.registry_3.5.400.v20140428-1507.jar,4,false
org.eclipse.equinox.security,1.2.0.v20130424-1801,plugins/org.eclipse.equinox.security_1.2.0.v20130424-1801.jar,4,false
org.eclipse.equinox.servletbridge.extensionbundle,1.3.100.201901181935,plugins/org.eclipse.equinox.servletbridge.extensionbundle_1.3.100.201901181935.jar,4,false
org.eclipse.equinox.simpleconfigurator,1.1.0.v20131217-1203,plugins/org.eclipse.equinox.simpleconfigurator_1.1.0.v20131217-1203.jar,1,true
org.eclipse.equinox.util,1.0.500.v20130404-1337,plugins/org.eclipse.equinox.util_1.0.500.v20130404-1337.jar,4,false
org.eclipse.help,3.6.0.v20130326-1254,plugins/org.eclipse.help_3.6.0.v20130326-1254.jar,4,false
org.eclipse.jetty.client,8.1.15.v20140411,plugins/org.eclipse.jetty.client_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.continuation,8.1.15.v20140411,plugins/org.eclipse.jetty.continuation_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.http,8.1.15.v20140411,plugins/org.eclipse.jetty.http_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.io,8.1.15.v20140411,plugins/org.eclipse.jetty.io_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.security,8.1.15.v20140411,plugins/org.eclipse.jetty.security_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.server,8.1.15.v20140411,plugins/org.eclipse.jetty.server_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.servlet,8.1.15.v20140411,plugins/org.eclipse.jetty.servlet_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.servlets,8.1.15.v20140411,plugins/org.eclipse.jetty.servlets_8.1.15.v20140411.jar,4,false
org.eclipse.jetty.util,8.1.15.v20140411,plugins/org.eclipse.jetty.util_8.1.15.v20140411.jar,4,false
org.eclipse.jetty9.websocket,1.0.0.v20141001-1004,plugins/org.eclipse.jetty9.websocket_1.0.0.v20141001-1004.jar,4,false
org.eclipse.jface,3.10.0.v20140604-0740,plugins/org.eclipse.jface_3.10.0.v20140604-0740.jar,4,false
org.eclipse.jface.databinding,1.6.200.v20140528-1422,plugins/org.eclipse.jface.databinding_1.6.200.v20140528-1422.jar,4,false
org.eclipse.jface.text,3.9.0.v20140521-1657,plugins/org.eclipse.jface.text_3.9.0.v20140521-1657.jar,4,false
org.eclipse.jgit,4.4.0.201606070830-r,plugins/org.eclipse.jgit_4.4.0.201606070830-r.jar,4,false
org.eclipse.orion.client.debug,1.0.0.v20190117-1659,plugins/org.eclipse.orion.client.debug_1.0.0.v20190117-1659.jar,4,false
org.eclipse.orion.server.authentication,1.0.0.v20170601-2114,plugins/org.eclipse.orion.server.authentication_1.0.0.v20170601-2114.jar,4,false
org.eclipse.orion.server.cf,1.0.0.v20171116-1531,plugins/org.eclipse.orion.server.cf_1.0.0.v20171116-1531.jar,4,false
org.eclipse.orion.server.core,1.0.0.v20171117-2131,plugins/org.eclipse.orion.server.core_1.0.0.v20171117-2131.jar,4,false
org.eclipse.orion.server.git,1.0.0.v20171005-2125,plugins/org.eclipse.orion.server.git_1.0.0.v20171005-2125.jar,4,false
org.eclipse.orion.server.hosting,1.0.0.v20150513-1949,plugins/org.eclipse.orion.server.hosting_1.0.0.v20150513-1949.jar,4,false
org.eclipse.orion.server.jetty,1.0.0.v20150306-0038,plugins/org.eclipse.orion.server.jetty_1.0.0.v20150306-0038.jar,4,false
org.eclipse.orion.server.jettycustomizer,1.0.0.v20150306-0038,plugins/org.eclipse.orion.server.jettycustomizer_1.0.0.v20150306-0038.jar,4,false
org.eclipse.orion.server.logback.config,1.0.0.v20160624-1719,plugins/org.eclipse.orion.server.logback.config_1.0.0.v20160624-1719.jar,4,false
org.eclipse.orion.server.logs,1.0.0.v20170427-1925,plugins/org.eclipse.orion.server.logs_1.0.0.v20170427-1925.jar,4,false
org.eclipse.orion.server.search,1.0.0.v20170427-1540,plugins/org.eclipse.orion.server.search_1.0.0.v20170427-1540.jar,4,false
org.eclipse.orion.server.servlets,1.0.0.v20170918-2114,plugins/org.eclipse.orion.server.servlets_1.0.0.v20170918-2114.jar,4,false
org.eclipse.orion.server.ui,1.0.0.v20150306-0038,plugins/org.eclipse.orion.server.ui_1.0.0.v20150306-0038.jar,4,false
org.eclipse.osgi,3.10.0.v20140606-1445,plugins/org.eclipse.osgi_3.10.0.v20140606-1445.jar,4,false
org.eclipse.osgi.compatibility.state,1.0.0.v20140403-1907,plugins/org.eclipse.osgi.compatibility.state_1.0.0.v20140403-1907.jar,4,false
org.eclipse.osgi.services,3.4.0.v20140312-2051,plugins/org.eclipse.osgi.services_3.4.0.v20140312-2051.jar,4,false
org.eclipse.rcp,4.3.100.v20140606-1215,plugins/org.eclipse.rcp_4.3.100.v20140606-1215.jar,4,false
org.eclipse.swt,3.103.0.v20140605-2008,plugins/org.eclipse.swt_3.103.0.v20140605-2008.jar,4,false
org.eclipse.swt.win32.win32.x86_64,3.103.0.v20140605-2012,plugins/org.eclipse.swt.win32.win32.x86_64_3.103.0.v20140605-2012.jar,4,false
org.eclipse.text,3.5.300.v20130515-1451,plugins/org.eclipse.text_3.5.300.v20130515-1451.jar,4,false
org.eclipse.ui,3.106.0.v20140519-0906,plugins/org.eclipse.ui_3.106.0.v20140519-0906.jar,4,false
org.eclipse.ui.console,3.5.300.v20140424-1437,plugins/org.eclipse.ui.console_3.5.300.v20140424-1437.jar,4,false
org.eclipse.ui.workbench,3.106.0.v20140530-0732,plugins/org.eclipse.ui.workbench_3.106.0.v20140530-0732.jar,4,false
org.eclipse.ui.workbench.texteditor,3.9.0.v20140411-1521,plugins/org.eclipse.ui.workbench.texteditor_3.9.0.v20140411-1521.jar,4,false
org.eclipse.update.configurator,3.3.300.v20140518-1928,plugins/org.eclipse.update.configurator_3.3.300.v20140518-1928.jar,4,false
org.json,1.0.0.v201011060100,plugins/org.json_1.0.0.v201011060100.jar,4,false
org.slf4j.api,1.7.2.v20121108-1250,plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
org.slf4j.jcl,1.7.2.v20130115-1340,plugins/org.slf4j.jcl_1.7.2.v20130115-1340.jar,4,false
org.slf4j.jul,1.7.2.v20121108-1250,plugins/org.slf4j.jul_1.7.2.v20121108-1250.jar,4,false
org.slf4j.log4j,1.7.2.v20130115-1340,plugins/org.slf4j.log4j_1.7.2.v20130115-1340.jar,4,false
org.w3c.css.sac,1.3.1.v200903091627,plugins/org.w3c.css.sac_1.3.1.v200903091627.jar,4,false
org.w3c.dom.events,3.0.0.draft20060413_v201105210656,plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar,4,false
org.w3c.dom.smil,1.0.0.v200806040011,plugins/org.w3c.dom.smil_1.0.0.v200806040011.jar,4,false
org.w3c.dom.svg,1.1.0.v201011041433,plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar,4,false
org.yaml.snakeyaml,1.14.0.v20150421-1508,plugins/org.yaml.snakeyaml_1.14.0.v20150421-1508.jar,4,false
Re: Orion WAR does not work [message #1801451 is a reply to message #1801423] Sat, 19 January 2019 15:59 Go to previous message
Resolved: I made a wrong guess and added the CLIENT and the SERVER update sites to my target (plus Kepler Eclipse platform) to build the war.
However, it looks like the CLIENT causes issues and only the SERVER updated site has to be added to the plugin development target.
Well, I have had to modify some dependency version to work with the org.eclipse.orion.client.core 2.0.0 version (which is the built version) instead of the referred 1.0.0 version.
Now, the server looks like starting despite I'm getting a 403 (Access denied) error after login as orion and admin user. But this is a different issue that I'm working to fix.
Previous Topic:Orion Node.js Futures
Next Topic:Code Map Ruler?
Current Time: Tue Dec 10 11:56:30 GMT 2024
Powered by FUDForum. Page generated in 0.04501 seconds
