Re: ExpressionBuilder left outer join with on clause [message #1801768 is a reply to message #1801759] |
Fri, 25 January 2019 23:26   |
Missing name Mising name Messages: 16 Registered: September 2011 |
A left outer join DEFINES what I want to happen, the Satellite row is returned and there is null Ephemeris data.
In the past, I used the non-ANSI SQL that set s.satelliteUid(+) = e.satelliteUid, but when that gets "involved" with another entity that uses ANSI SQL left outer joins, the two collide and an error is given that states that the non-
ANSI SQL cannot be used, which is why I am trying to figure out how to enter is this way. But every example that is close, makes no difference in the query. And I am NOT using a @OneToOne relationship mapping, I am using a @SecondaryTable. MAYBE that is the problem???
[Updated on: Fri, 25 January 2019 23:27] Report message to a moderator
FUDForum. Page generated in 0.02685 seconds
