Home » Eclipse Projects » BIRT » Report parameter combo box not populating
Report parameter combo box not populating [message #1801266] Wed, 16 January 2019 04:37 Go to next message
Tony Wolsey is currently offline Tony WolseyFriend
Hello
Please forgive the simple question but I am a very new user.
I am trying to create a simple report parameter and have a combo box appear at runtime for the person to select. I am connecting to a MySQL DB.
1. I have created a report parameter (rp_companyname), selected combo box, selected dynamic list, selected the dataset (Test25), selected the value column (company_name).
2. Then I inserted a parameter marker in the SQL query for Test25 dataset
select customers.company_name,
customers.contact_name,
customers.country
from customers
where customers.company_name = ?
I then edited the parameter in dataset Test25 to link to rp_companyname.
When I run the report to PDF (for example), I see the parameter dialog box, but the combo box is empty.
Note that I have also tried to use a static list of values for the combo box but when I try to import the values in the Report Parameter dialog box, the values are empty also.
What am I doing wrong and/or what else must I do to make this work?
thanks
Tony
Re: Report parameter combo box not populating [message #1801330 is a reply to message #1801266] Thu, 17 January 2019 01:43 Go to previous messageGo to next message
Colin Sutton is currently offline Colin SuttonFriend
Your test25 dataset should be:
from customers
without the where clause
[Updated on: Thu, 17 January 2019 01:44]
Report message to a moderator
Re: Report parameter combo box not populating [message #1801331 is a reply to message #1801330] Thu, 17 January 2019 03:10 Go to previous message
you are brilliant Colin!
I was following the instruction in the help menu for BIRT where it instructed me to "insert a parameter marker in the SQL query". I am clear now that I should not of added the where clause.
thanks
Tony
Previous Topic:Report parameter combo box not populating #2
Next Topic:Dynamic combo box doesn't pass value field
Current Time: Sun Aug 18 11:36:02 GMT 2019
Powered by FUDForum. Page generated in 0.01496 seconds
