Home » Eclipse Projects » Eclipse Platform » RCP config.ini not working since updating to Eclipse 4.9
RCP config.ini not working since updating to Eclipse 4.9 [message #1801145] Mon, 14 January 2019 15:32 Go to next message
Phil Beauvoir is currently offline Phil BeauvoirFriend
Member
I use a custom config.ini file for my RCP application which is built on Eclipse 4.7. Since updating to Eclipse 4.9 it no longer works, such that when launching the RCP application there is an error.
Here is the config.ini:
eclipse.application=com.archimatetool.editor.app
osgi.bundles.defaultStartLevel=4
eclipse.product=com.archimatetool.editor.product
osgi.splashPath=platform:/base/plugins/com.archimatetool.editor
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.equinox.ds@3:start,org.eclipse.core.runtime@start
And the error log is attached.
Note that the app does not use the org.eclipse.equinox.simpleconfigurator plugin as it allows the user to add plugins into the app's "plugins" folder.
  • Attachment: error.log
    (Size: 4.39KB, Downloaded 60 times)
Re: RCP config.ini not working since updating to Eclipse 4.9 [message #1801155 is a reply to message #1801145] Mon, 14 January 2019 17:07 Go to previous messageGo to next message
Member
Could it be a problem with org.eclipse.update.configurator?
See https://github.com/diffplug/goomph/issues/69
Re: RCP config.ini not working since updating to Eclipse 4.9 [message #1801193 is a reply to message #1801155] Tue, 15 January 2019 06:26 Go to previous messageGo to next message
It's probably related to this thread as well:
https://www.eclipse.org/forums/index.php/mv/msg/1096972/1800881/#msg_1800881
Ed Merks
Re: RCP config.ini not working since updating to Eclipse 4.9 [message #1801198 is a reply to message #1801193] Tue, 15 January 2019 08:23 Go to previous message
Member
Ed Merks wrote on Tue, 15 January 2019 06:26
Thanks, Ed.
Previous Topic:Eclipse 2018-12 exhibits quite a few UI usability issues (at least for Fedora 27)
Next Topic:Code folding bar color?
Current Time: Sat Sep 19 17:44:18 GMT 2020
Powered by FUDForum. Page generated in 0.01936 seconds
