Home » Eclipse Projects » Sirius » How to convert sirius projects to eclipse RCP project ?
How to convert sirius projects to eclipse RCP project ? [message #1800966] Thu, 10 January 2019 12:26 Go to next message
Lalit Solanki is currently offline Lalit SolankiFriend
Hi Friends,
I have 4 sirius project and now i try to convert into eclipse RCP project.
I have below project
enterprisecoremodel
enterprisecoremodel.edit
enterprisecoremodel.editor
enterprisecoremodel.design
I have created normal eclipse RCP application and create one product file then
I added to above 4 projects and added required plugins.
Run the RCP application and create inside RCP application one modeling project and
viewpoint specification project.
I have created model file, crated .aird file, .enterprisemodel file and then
right click to open enterprise file but it is not opening so can u please help me
where is my mistake.
If required anything more info then let me know.
Lalit
Lalit
Re: How to convert sirius projects to eclipse RCP project ? [message #1801216 is a reply to message #1800966] Tue, 15 January 2019 14:31 Go to previous message
Florian Barbin is currently offline Florian BarbinFriend
Have you created the .enterprisemodel file by using the File > New > Other wizard (or right click on the project, New > Other)? In that case the enterprisecoremodel.editor plugin is properly installed so you should be able to edit your model file. Note that this mechanism is not specific to Sirius but provided by EMF.
If you have some trouble to open the Sirius Session, make sure that the Sirius plugins are installed in your RCP product.
Florian
Previous Topic:Problem with custom layout provider
Next Topic:Ordering of elements in model vs. aird files matters?
Current Time: Mon Aug 10 16:57:33 GMT 2020
Powered by FUDForum. Page generated in 0.01236 seconds
