Statistic verdict for TTCN [message #1800827] |
Tue, 08 January 2019 19:13 |
David Laurent Messages: 68 Registered: September 2018 |
Member |
Hi Elmer,
Would it be possible to display in the logs the following overall general verdict to a specific test case verdict from the [LOGGING] section or other means ?
STATISTICS_VERDICT - Verdict statistics: 0 none (0.00 %), 2 pass (100.00 %), 0 inconc (0.00 %), 0 fail (0.00 %), 0 error (0.00 %)
To: for instance
TC_01: 0 none (0.00 %), 1 pass (100.00 %), 0 inconc (0.00 %), 0 fail (0.00 %), 0 error (0.00 %)
TC_02: 0 none (0.00 %), 1 pass (100.00 %), 0 inconc (0.00 %), 0 fail (0.00 %), 0 error (0.00 %)
Regards - David
[Updated on: Tue, 08 January 2019 19:13] Report message to a moderator
Re: Statistic verdict for TTCN [message #1800857 is a reply to message #1800827] |
Wed, 09 January 2019 08:08 |
Hi David,
it has not been implemented as each user has different post-processing requirements.
However, there's an Eclipse Titan plug-in named LogViewer which does exactly the same as you requested namely displaying a list of test cases and their verdict, based on the log file generated by Titan.
The documentation of the LogViewer is only available in the Eclipse Help.
The other alternative of course is to do a simple post-processing with grep or awk.
Best regards
Elemer
FUDForum. Page generated in 0.03907 seconds
