Home » Eclipse Projects » NatTable » Dynamically set column span for a cell(i want to randomly set column span for a cell based on value in other column)
Dynamically set column span for a cell [message #1800783] Tue, 08 January 2019 08:52 Go to next message
Shreya Suman is currently offline Shreya SumanFriend
My requirement is to based on a value selected in a column of nattable, i want to set a custom text by merging few other column and make it non-editable.
i am able to achieve the non-editable cell using label configuration but i am not able to achieve row spanning / merging dynamically,
i have defined in my get cell as:
public DataCell getCellByPosition(int columnPosition, int rowPosition)
int columnSpan = 1;
int rowSpan = 1;
int cellColumnPosition = columnPosition;
int cellRowPosition = rowPosition;
//Merge the load current cells if component is excluded from fuse size analysis
if(rowObj.isExcludedFromFuseSizeAnalysis())
if(cellColumnPosition == gfsConstant.NOM_COL_IDX)
columnSpan = 6;
return new DataCell(cellColumnPosition, cellRowPosition, columnSpan, rowSpan);
when i save the data in database and after i reload the table the span is showing correctly, but i want it to display as soon as i edit the property in other column.
Can someone please help me in how to achieve this.
  • Attachment: Capture.PNG
    (Size: 14.70KB, Downloaded 46 times)
Re: Dynamically set column span for a cell [message #1800785 is a reply to message #1800783] Tue, 08 January 2019 09:41 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
I suppose you need to trigger a NatTable#refresh() after updating the value. You should be able to do this by either registering a custom UpdateDataCommandHandler to the body DataLayer or by registering a listener for a DataUpdateEvent that triggers the refresh if the update contains the value. At least that would be my assumption without seeing any other code or having a simple example to reproduce this.
Previous Topic:Filter Not working when column cell value contains "*"
Next Topic:Problem with Tree and Hide Row
Current Time: Tue Aug 04 15:13:21 GMT 2020
Powered by FUDForum. Page generated in 0.04936 seconds
