Home » Eclipse Projects » Sirius » How to perform operation only for disabled cells in Sirius table
How to perform operation only for disabled cells in Sirius table [message #1800062] Wed, 19 December 2018 12:16 Go to next message
Prajna VGFriend
Member
Hi all,
In Sirius, In a table I have several columns which are the properties of objects in line. When we click a line all columns which are its properties we can edit those cells and all which are not properties we can not edit those cells.
When I debug the code I got that enabled cells are considered as DCellSpec and disabled cells are considered as DLineSpec.
How I can do any operation like changing the color only for those disabled cells.
Thanks in advance
[Updated on: Wed, 19 December 2018 12:22]
Report message to a moderator
Re: How to perform operation only for disabled cells in Sirius table [message #1800127 is a reply to message #1800062] Thu, 20 December 2018 09:48 Go to previous message
Steve Monnier is currently offline Steve MonnierFriend
In fact, the process is that by default you have a DLine concerning a semantic element. If the element has a feature maching the "Feature Column" then a DCell is created. Therefore, is you have a different style for the "Line Mapping" and the "Feature Column" you will have the differenciation that you are looking for.
Steve
Steve Monnier - Obeo
Previous Topic:Viewpoint Specification Project
Next Topic:Update aird file when change the uri of sementic resource
Current Time: Tue Mar 02 05:03:04 GMT 2021
Powered by FUDForum. Page generated in 0.01771 seconds
