Home » Eclipse Projects » Sirius » conditionally hiding a visual element(conditionally hiding a visual element)
conditionally hiding a visual element [message #1799776] Thu, 13 December 2018 12:11 Go to next message
Neil Mackenzie is currently offline Neil MackenzieFriend
Hello, I really like the new visibilty mode in Sirius.
I use sirius and the .odesign file to display a graph of nodes and edges, and for some of the nodes I would like to conditionally hide them according to some attribute on the object..This would make a subset of the nodes visible, but in visibility mode I would be able to see the full set of nodes, with the subset fully visible and the others 'greyed out'.
I know I can use conditional styling to have different colors for examle, but is there any way to do conditional visibility of a node?
I have attached a screenshot of the kind of effect I am trying to achieve
Neil
Re: conditionally hiding a visual element [message #1799785 is a reply to message #1799776] Thu, 13 December 2018 13:23 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
From what I understand of your description, it seems that filters is what you want to use in this case.
Pierre-Charles
Pierre-Charles David - Obeo
Re: conditionally hiding a visual element [message #1799792 is a reply to message #1799785] Thu, 13 December 2018 14:35 Go to previous message
Thanks! I will try that out.
Previous Topic:Change colour of specific node from code
Next Topic:StackOverlow Error with Sirius diagram
Current Time: Fri Mar 05 01:05:48 GMT 2021
Powered by FUDForum. Page generated in 0.02347 seconds
