Home » Eclipse Projects » BIRT » Merging Similar Data of multiple rows and showing as one(Merging Similar Data of multiple rows and showing as one)
Merging Similar Data of multiple rows and showing as one [message #1798546] Tue, 20 November 2018 10:26 Go to next message
Arun Kumar is currently offline Arun KumarFriend
Could any one let me know how to merge the rows with same data under a column into one row. I have tried suppress duplicates option but still the rows are remaining even though the duplicates under a column are removed. But this is not the feasible solution that I want . Could you please look at the screenshots that I got and what I want exactly and help me out with that.
Arun
Re: Merging Similar Data of multiple rows and showing as one [message #1835403 is a reply to message #1798546] Wed, 02 December 2020 14:05 Go to previous messageGo to next message
Nikolai Elders is currently offline Nikolai EldersFriend
Hi Arun,
Did you manage to solve this problem? If so, what did you do?
Re: Merging Similar Data of multiple rows and showing as one [message #1835405 is a reply to message #1835403] Wed, 02 December 2020 14:29 Go to previous messageGo to next message
dmitry khotsko is currently offline dmitry khotskoFriend
Member
I get structures like this using UPDATE tables in db
Re: Merging Similar Data of multiple rows and showing as one [message #1835581 is a reply to message #1798546] Mon, 07 December 2020 14:53 Go to previous message
rbaak Mising name is currently offline rbaak Mising nameFriend
Member
Try Using a crosstab report. You would need to build a data cube first. Not sure if you would still be able to keep your column order but you would get the merge you want.
Previous Topic:How do I display MIN date of a field in BIRT
Next Topic:Max File Size pdf
Current Time: Wed Oct 20 10:10:00 GMT 2021
Powered by FUDForum. Page generated in 0.01802 seconds
