Re: Can't edit cell in sirius table after getting error [message #1798216 is a reply to message #1798214] |
Wed, 14 November 2018 09:50 |
Hello
Once you get the error dialog box it is too late and moreover you do not want to see that awful dialog box.
So I would agree with your second proposition that is using a service to check the value and to manage wrong matching with the requested value type.
Peering your Value Interpreted Expression, it seems that you miswrote the arg0 argument. You used opening and closing parenthesis instead of 0 digit.
Laurent
Laurent Fasani - Obeo
Re: Can't edit cell in sirius table after getting error [message #1798436 is a reply to message #1798384] |
Mon, 19 November 2018 04:34 |
Prajna VG Messages: 54 Registered: July 2018 |
Member |
Hi Laurent,
Yeah, That code I used is for setValue().
If I use setValue(arg0) I'm using
public static String setValue(EObject self,String arg) {
//self
System.out.println(self.toString());
System.out.println(arg.toString());
return "22";
But I am getting NPE. It is not displaying those sysout statements in console also. So I guess it is not considering that method even though I pass a String arg!!
I tried by this also
public static String setValue(EObject self,String args[]) {
//self
return "22";
How can I give a method so that it returns integer data type.
[Updated on: Mon, 19 November 2018 05:03] Report message to a moderator
Re: Can't edit cell in sirius table after getting error [message #1798626 is a reply to message #1798436] |
Wed, 21 November 2018 09:57 |
Prajna VG wrote on Mon, 19 November 2018 05:34Hi Laurent,
//self
return "22";
How can we help if you do not give us actual details about the NPE (e.g. a stack trace)?
//self
return "22";
The documentation page Laurent already pointed you at clearly mentions that "array types are not supported" for the arguments of service methods.
I just tested, and a service method which returns an int works perfectly fine.
public int nodeBorderSize(EClass klass) {
return klass.getName().length();
Pierre-Charles David - Obeo
Re: Can't edit cell in sirius table after getting error [message #1800137 is a reply to message #1798626] |
Thu, 20 December 2018 11:12 |
Member |
Hi Pierre,
I tried using service method it is working for integer value if I set value expression service:setValue(arg0)
But if I enter alphabetical value we are getting java.lang.IllegalArgumentException
Below is the stack trace of my code.
!ENTRY org.eclipse.ui 4 0 2018-12-20 16:33:56.629
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException: The value 'hn' is invalid. java.lang.NumberFormatException: For input string: "hn"
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFactoryImpl.java:470)
at autosar40.genericstructure.generaltemplateclasses.primitivetypes.impl.PrimitivetypesFactoryImpl.createPositiveIntegerFromString(PrimitivetypesFactoryImpl.java:886)
at autosar40.genericstructure.generaltemplateclasses.primitivetypes.impl.PrimitivetypesFactoryImpl.createFromString(PrimitivetypesFactoryImpl.java:163)
at org.eclipse.sirius.table.ui.tools.internal.editor.provider.DFeatureColumnEditingSupport.setValue(DFeatureColumnEditingSupport.java:245)
at org.eclipse.jface.viewers.EditingSupport.saveCellEditorValue(EditingSupport.java:113)
at org.eclipse.jface.viewers.ColumnViewerEditor.saveEditorValue(ColumnViewerEditor.java:453)
at org.eclipse.jface.viewers.ColumnViewerEditor.applyEditorValue(ColumnViewerEditor.java:309)
at org.eclipse.jface.viewers.ColumnViewerEditor.handleEditorActivationEvent(ColumnViewerEditor.java:436)
at org.eclipse.jface.viewers.ColumnViewer.triggerEditorActivationEvent(ColumnViewer.java:677)
at org.eclipse.sirius.table.ui.tools.internal.editor.DTableTreeViewer.triggerEditorActivationEvent(DTableTreeViewer.java:109)
at org.eclipse.jface.viewers.ColumnViewer.handleMouseDown(ColumnViewer.java:652)
at org.eclipse.jface.viewers.ColumnViewer.access$0(ColumnViewer.java:648)
at org.eclipse.jface.viewers.ColumnViewer$1.mouseDoubleClick(ColumnViewer.java:103)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:197)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NumberFormatException: For input string: "hn"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Long.parseLong(Unknown Source)
at java.lang.Long.valueOf(Unknown Source)
at org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFactoryImpl.java:454)
... 40 more
and after we can not edit that cell. Can anyone help me on how I can enable that cell after getting that error.
[Updated on: Thu, 20 December 2018 11:13] Report message to a moderator
FUDForum. Page generated in 0.02274 seconds
