Home » Newcomers » Newcomers » Force.com IDE login in to Salesforce(Eclipse does nothing when I click "next" and try to login to a Sandbox)
Force.com IDE login in to Salesforce [message #1798205] Wed, 14 November 2018 08:22 Go to next message
Richard Blackman is currently offline Richard BlackmanFriend
Hello
Can anyone help I am a new comer to Eclipse. I am trying to use Eclipse to login to a Salesforce Sandbox.
I have a Mac running Mojave 10.14.1 , I have installed Eclispe:
Version: 2018-09 (4.9.0)
Build id: 20180917-1800
I have installed JDK 11.0.1 64 bit from the Oracle Website
I have followed the instructions on force.com and installed the Force.com IDE plugin for Eclispe.
All of this seems to be working fine. I have opened Eclipse and then opened a new perspective for force. com.
Next I have tried to create a new Force.com project. When I right click and select New > Force.com project, nothing happens, no errors just nothing.
So I use the Project option instead, this works. From the Wizard I select Force.com > Force.com Project. I click the "Next" button once, nothing happens, I click it a second time and the Project Name / Login screen appears. I enter the mandatory details (Project Name, Username, password etc.). When I click the "Next" button nothing happens? No error messages no spinning wheels, just nothing. Can anyone help? Have I missed something in the install? Or is there another setting on my Mac I need to adjust. If anyone has anyone else has had this issue please let me know how you resolve it.
Re: Force.com IDE login in to Salesforce [message #1798242 is a reply to message #1798205] Wed, 14 November 2018 15:51 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You'll have to contact the developer of the Force.com IDE plugin.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Force.com IDE login in to Salesforce [message #1798318 is a reply to message #1798242] Thu, 15 November 2018 09:56 Go to previous messageGo to next message
Thanks for the reply Nitin. I will follow this up on the force.com site.
Re: Force.com IDE login in to Salesforce [message #1798493 is a reply to message #1798318] Mon, 19 November 2018 20:00 Go to previous messageGo to next message
Cody Johnson is currently offline Cody JohnsonFriend
Did you ever get a response from force.com? I am having the same issue, but when I open it through the Project wizard it does nothing after I enter all my info and try to connect to our Salesforce build.
Re: Force.com IDE login in to Salesforce [message #1798891 is a reply to message #1798493] Tue, 27 November 2018 05:14 Go to previous messageGo to next message
hector diaz is currently offline hector diazFriend
hello, good night could solve the problem, I have the same situation?
regards
Re: Force.com IDE login in to Salesforce [message #1798938 is a reply to message #1798205] Tue, 27 November 2018 16:13 Go to previous messageGo to next message
Lakis Juzwa is currently offline Lakis JuzwaFriend
Hey guys,
Same situation here. Reached same stage as @Richard Blackman - nothing happens after pressed "Next".
I have an SF org with custom domain and I'm using:
macOS Mojave 10.14.1
Eclipse IDE for Java Developers: Version: 2018-09 (4.9.0) | Build id: 20180917-1800.
Java version: 11.0.1
Lakis
Re: Force.com IDE login in to Salesforce [message #1798955 is a reply to message #1798938] Tue, 27 November 2018 23:41 Go to previous messageGo to next message
Dennis Yoo is currently offline Dennis YooFriend
I am having the same issue. Start a new Force.com Project, enter my salesforce credentials and token, nothing happens. No error message or anything.
Re: Force.com IDE login in to Salesforce [message #1800613 is a reply to message #1798205] Thu, 03 January 2019 16:58 Go to previous messageGo to next message
Matt Bostrom is currently offline Matt BostromFriend
I am also experiencing the EXACT same issue on the MacBook 2018 Mojave. Has anyone found the solution?
Maven's Mate was a great alternative to Force.com IDE now that is gone. What else is a good IDE (Visual Studio Code only works with scratch orgs I think).
Re: Force.com IDE login in to Salesforce [message #1800661 is a reply to message #1798205] Fri, 04 January 2019 16:52 Go to previous messageGo to next message
Sid Mathur is currently offline Sid MathurFriend
Exactly same issue. Any help will be very much appreciated. Thanks.
Re: Force.com IDE login in to Salesforce [message #1802267 is a reply to message #1800661] Tue, 05 February 2019 14:51 Go to previous messageGo to next message
Greta Mickunaite is currently offline Greta MickunaiteFriend
I have exactly same issue. Has anyone found the solution?
Re: Force.com IDE login in to Salesforce [message #1805998 is a reply to message #1802267] Tue, 30 April 2019 09:50 Go to previous messageGo to next message
Luke Attard Bason Esteban is currently offline Luke Attard Bason EstebanFriend
Same issue over here... can someone post a solution?
Re: Force.com IDE login in to Salesforce [message #1808270 is a reply to message #1798205] Thu, 20 June 2019 20:27 Go to previous messageGo to next message
Scott Morirson is currently offline Scott MorirsonFriend
Same issue here
I created a blank project and then added the force.com nature and put in credentials. This worked and it proceeded to download all the metadata from the org but there is no package.xml. If I try and change the contents of the project I get the following error
Unable to create the selected property page.
javax/xml/bind/JAXBException
Re: Force.com IDE login in to Salesforce [message #1810684 is a reply to message #1798205] Fri, 16 August 2019 05:18 Go to previous messageGo to next message
Isabel Jason is currently offline Isabel JasonFriend
This issue is actually caused by Windows 7 UAC (User Access Control) which doesn't allow Eclipse to be updated if you're running it from within the c:\program files directory. Eclipse doesn't know how to handle that problem and stupidly reports some misleading conflict information. I've moved my Eclipse install to c:\eclipse and it's working fine now.
Salesforce platform allows users to configure with any software, but initially, the sys setup is required to be monitored.
Re: Force.com IDE login in to Salesforce [message #1823703 is a reply to message #1798938] Tue, 31 March 2020 11:01 Go to previous message
sri knth is currently offline sri knthFriend
This problem is actually caused by Windows 7 UAC (User Access Control), which prevents Eclipse from updating if you run it from the c: \ program files directory. Eclipse does not know how to deal with this problem, and foolishly reports misleading conflict information. I moved the Eclipse installation to c: \ eclipse and now it works fine.
The Salesforce platform allows users to customize any software, but first you need to track the system configuration.
Previous Topic:How to unistall Eclipse (Win10)
Next Topic:eclipse startup issue
Current Time: Tue Jun 02 15:32:01 GMT 2020
Powered by FUDForum. Page generated in 0.03960 seconds
