Cannot launch BlinkTest application [message #1798121] |
Tue, 13 November 2018 03:38 |
Barry Dowdeswell Messages: 49 Registered: November 2018 |
Member |
I am working through the BlinkTest tutorial but I am getting an error whenever I try to deploy the application.
All occurrences of MGR_ID that I can find in the application are set to "localhost:61499" but it reports that the property is null in FORTE_PC.EMB_RES
I noticed that the documentation says that the button is called "Download" but in 4DIAC it shows "Deploy" ? Is that a setting I have missed?
A screen shot of the error is attached. I have circled the MGR_ID property that looks suspicious but I cannot see where to set it.
Thanks in advance for your help. I could not find a similar topic to this on the forum so I apologize if I have missed it somewhere.
Barry
[Updated on: Tue, 13 November 2018 03:38] Report message to a moderator
Re: Cannot launch BlinkTest application [message #1798137 is a reply to message #1798121] |
Tue, 13 November 2018 08:47 |
we also identified that our tutorials are a bit outdated. Therefore we started to improve them for the 1.10.0 release (see this Bug [1] for more details). Andrea reworked already some of them. We haven't put them yet on the web-page but they are already part of the 4diac help in the 4diac IDE 1.10.0 prereleases.
As I look on your problem it seems anyhow that there is an issue somewhere else. May I ask which 4diac IDE version you are using?
With 1.10 we also reworked the deployment quite a lot. As 1.10.0 is just arround the corner, I would recommend that you update your IDE to the latest development version. This would not only give you an improved deployment but also the latest docs.
The easyiest way to update would be to add the link http://download.eclipse.org/4diac/nightly/update to the Available update Sites (Menu: Window -> Preferences -> Install/Update -> Available Software Sites). Then you can check and install updates under Help -> Check for updates.
cheers,
Alois
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=539344
Re: Cannot launch BlinkTest application [message #1798281 is a reply to message #1798276] |
Wed, 14 November 2018 20:38 |
Barry,
great to hear that. With 1.10.0 RC2 on each start 4diac IDE will check if there are updates available. And inform you with a small pop-up on the bottom left. Andrea is continuously updating the tutorials so you can expect improvements over the next days. Feedback on the tutorials is highly appreciated.
Alois
FUDForum. Page generated in 0.02268 seconds
