Home » Eclipse Projects » EclipseLink » Local Exception Stack:(Local Exception Stack: Error)
Local Exception Stack: [message #1798063] Mon, 12 November 2018 07:30 Go to next message
hussain namdari is currently offline hussain namdariFriend
i have been tried all the ways that mentioned previously but this error is not getting away kindly support :-
this is the Error Message :-
Exception in thread "AWT-EventQueue-0" Local Exception Stack:
Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: sun.misc.Launcher$AppClassLoader@232204a1
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [test?zeroDateTimeBehavior=convertToNullPU] failed.
Internal Exception: Exception [EclipseLink-7244] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
Exception Description: An incompatible mapping has been encountered between [class test1.Roles] and [class test1.SubDepartment]. This usually occurs when the cardinality of a mapping does not correspond with the cardinality of its backpointer.
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(PersistenceUnitLoadingException.java:127)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:107)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:177)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:79)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:54)
at test1.EmployeeCenter.initComponents(EmployeeCenter.java:53)
at test1.EmployeeCenter.<init>(EmployeeCenter.java:35)
at test1.EmployeeCenter$4.run(EmployeeCenter.java:436)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.createPredeployFailedPersistenceException(EntityManagerSetupImpl.java:1954)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1945)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:98)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:96)
... 20 more
Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.EntityManagerSetupException
at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:230)
... 24 more
Caused by: Exception [EclipseLink-7244] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
at org.eclipse.persistence.exceptions.ValidationException.invalidMapping(ValidationException.java:1293)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.OneToManyAccessor.processOneToManyMapping(OneToManyAccessor.java:252)
at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.OneToManyAccessor.process(OneToManyAccessor.java:143)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processNonOwningRelationshipAccessors(MetadataProject.java:1566)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage3(MetadataProject.java:1855)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:580)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:585)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1869)
... 22 more
Thanks Again
Re: Local Exception Stack: [message #1798644 is a reply to message #1798063] Wed, 21 November 2018 19:34 Go to previous message
Chris Delahunt is currently offline Chris DelahuntFriend
What have you tried exactly? The error "Exception Description: An incompatible mapping has been encountered between [class test1.Roles] and [class test1.SubDepartment]. This usually occurs when the cardinality of a mapping does not correspond with the cardinality of its backpointer." indicates a mapping issue - we would need to see the mappings involved to be able to help.
Previous Topic:External Cache for EclipseLink
Next Topic:Custom Object IN Parameter
Current Time: Wed Jul 24 12:12:51 GMT 2024
Powered by FUDForum. Page generated in 0.03904 seconds
