Home » Archived » Eclipse SmartHome » OSGi test problem: missing constraints
OSGi test problem: missing constraints [message #1798002] Fri, 09 November 2018 23:21 Go to next message
Dominik Schlierf is currently offline Dominik SchlierfFriend
Hello everyone :)
I just added an OSGi test to my new Time Condition, but when I try to run the test configuration in org.eclipse.smarthome.automation.module.timer.test it gives me the message that theres a missing constraint. One of these is the import package org.eclipse.smarthome.test. When I add this package to the run configuration plug ins I get even more missing constraints.
Can anyone tell me what I am doing wrong?
Re: OSGi test problem: missing constraints [message #1798098 is a reply to message #1798002] Mon, 12 November 2018 12:53 Go to previous messageGo to next message
Henning Treu is currently offline Henning TreuFriend
Member
Hi Dominik,
the launch configs sometimes get outdated so the process you already started is the way to go: Add org.eclipse.smarthome.test to the import packages and you probably have to add javax.servlet along with some jetty packages. You are welcome to also contribute the updated launch config with your PR.
Henning
Re: OSGi test problem: missing constraints [message #1798198 is a reply to message #1798098] Wed, 14 November 2018 06:16 Go to previous message
Oh ok, thank you - I will update it as soon as possible then! :)
Previous Topic:Need help understanding the rules engine implementation
Next Topic:ESH + Authorisation + OPTIONS method
Current Time: Sat Jul 04 10:24:56 GMT 2020
Powered by FUDForum. Page generated in 0.15396 seconds
