Deployment fails [message #1797697] |
Mon, 05 November 2018 11:33 |
Hans-Jürgen Labrador Messages: 4 Registered: October 2018 |
As a newbie I tried scout and wanted to know if scout can help me in development. Unfortunately I spent a lot of time and cant get it to run. As far as I use only the dev-Environment its all fine and I can use it. However I would like to know how it works in a more produktive environment. I created just the helloworld app which comes in default. I deployed this first to Azure but as I pointed in another issue it doesnt work. I suspected azure and I installed a naked Tomcat 8.5.34 but what can I say, it doesnt work too. The server part is deployable but the ui.html its not. Attached is the stack. I mean its a standard Tomcat installation on localhost, I use only http on port 8080 (actually follow exactly your sample in documentation) and cant understand why the new created helloworld is not even deployable. This is the minimum I expect from a framework, opensource or not.
2018-11-05 12:28:02,720 ERROR [scout-thread-24] org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller - Error receiving client notifications - MDC[principal=notification-authenticator, jobName=ClientNotificationPoller]
org.eclipse.scout.rt.platform.exception.PlatformException: 403 - FORBIDDEN [translator=org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator, user=notification-authenticator, remote-service.name=org.eclipse.scout.rt.shared.clientnotification.IClientNotificationService, remote-service.operation=getNotifications]
at org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator.translateInternal(DefaultRuntimeExceptionTranslator.java:54)
at org.eclipse.scout.rt.platform.exception.DefaultRuntimeExceptionTranslator.translate(DefaultRuntimeExceptionTranslator.java:37)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.interceptException(AbstractServiceTunnel.java:156)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:55)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:40)
at org.eclipse.scout.rt.shared.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:191)
at org.eclipse.scout.rt.shared.servicetunnel.ServiceTunnelProxyProducer.invoke(ServiceTunnelProxyProducer.java:51)
at org.eclipse.scout.rt.platform.interceptor.DecoratingProxy.invokeImpl(DecoratingProxy.java:137)
at org.eclipse.scout.rt.platform.interceptor.DecoratingProxy$P_InvocationHandler.invoke(DecoratingProxy.java:170)
at com.sun.proxy.$Proxy54.getNotifications(Unknown Source)
at org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller$P_NotificationPoller$1.run(ClientNotificationPoller.java:109)
at org.eclipse.scout.rt.platform.util.concurrent.Callables.lambda$0(Callables.java:31)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxMandatory(TransactionProcessor.java:143)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:126)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:71)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:156)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:137)
at org.eclipse.scout.rt.platform.context.RunContext.run(RunContext.java:108)
at org.eclipse.scout.rt.client.clientnotification.ClientNotificationPoller$P_NotificationPoller.run(ClientNotificationPoller.java:104)
at org.eclipse.scout.rt.platform.job.internal.ExceptionProcessor.intercept(ExceptionProcessor.java:41)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequiresNew(TransactionProcessor.java:100)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:129)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
at org.eclipse.scout.rt.platform.job.internal.CallableChainExceptionHandler.intercept(CallableChainExceptionHandler.java:31)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.lambda$0(JobFutureTask.java:97)
at java.util.concurrent.FutureTask.run(Unknown Source)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:63)
at org.eclipse.scout.rt.shared.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:64)
Caused by: org.eclipse.scout.rt.shared.servicetunnel.HttpException: 403 - FORBIDDEN
Thx Hans-Juergen
Re: Deployment fails [message #1798073 is a reply to message #1798010] |
Mon, 12 November 2018 08:31 |
Apparently the service tunnel request from the UI server is rejected by the backend server's security filter. To determine the reason, you can try to change the log level to DEBUG or TRACE (logback.xml). If that does not show more detail on the error, start Tomcat in debug mode, attach the Eclipse debugger to it and add a break point in your "...ServerServletFilter" doFilter() method. You can then inspect each step of the autentication process.
Beat
FUDForum. Page generated in 0.03510 seconds
