Re: Protocol message specifications [message #1797515 is a reply to message #1797514] |
Thu, 01 November 2018 02:42 |
Hi Dimo,
What you describe is a concept that was often requested in legacy tooling: the concept of a cable the can contain multiple connectors, each with their own protocol. It was discussed as a potential addition to the language, but it was never assigned to an MVP - mostly a matter of prioritization where parity with legacy tooling was primordial.
However, you could define a protocol that would do what you want by, for example, have a "forward" property that would specify on which port the message would be forwarded. This means that, on reception, it would process this (or these) elements to be forwarded to their final destination. You may still have to handle synchronisation in some way, as the semantics of the state machines will still process one message, to completion, at the time.
/Charles Rivet
Re: Protocol message specifications [message #1797562 is a reply to message #1797547] |
Thu, 01 November 2018 17:56 |
You're welcome,
By the way, Papyrus for Real Time has its own forum where you have a better chance of interacting with the Papyrus-RT experts out there. Not every one 06 them monitors the newcomers (this) forum.
/Charles Rivet
FUDForum. Page generated in 0.06410 seconds
