Home » Modeling » M2T (model-to-text transformation) » input model
input model [message #1796729] Thu, 18 October 2018 08:10 Go to next message
annachiara marano is currently offline annachiara maranoFriend
hello to all
I have to input in the "acceleo lunch" a model that is in the eclipse rutime, I do not understand how I should do because it is not in my "workspace". Could someone help me?
Thanks for the attention
Annachiara
Re: input model [message #1796743 is a reply to message #1796729] Thu, 18 October 2018 11:11 Go to previous message
You should be able to refer to a metamodel input as e.g. http://www.eclipse.org/emf/2002/Ecore
You should be able to refer to a model input as e.g. platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore or platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore
You may also check out the relevant plugin so that it is in your workspace.
Ed Willink
Previous Topic:c.getAppliedStereotypes().name doesn't work in acceleo template
Next Topic:programmatically check if the generation Was successfull
Current Time: Tue Jan 18 14:35:11 GMT 2022
Powered by FUDForum. Page generated in 0.01915 seconds
