Home » Eclipse Projects » Sirius » Merge a memory leak defect from Sirius 6.0 to Sirius 4.1.3
Merge a memory leak defect from Sirius 6.0 to Sirius 4.1.3 [message #1796548] Tue, 16 October 2018 02:19 Go to next message
mind calm is currently offline mind calmFriend
Member
Last year i report a memory leak problem on https://www.eclipse.org/forums/index.php/m/1771830/#msg_1771830 and https://bugs.eclipse.org/bugs/show_bug.cgi?id=521718
I saw Sirius have fixed it at Sirius 6.0.0, now i want to merge the related codes from Sirius 6.0.0 to Sirius 4.1.3, which version i used in my platform.
I saw the commit on git, https://git.eclipse.org/r/#/c/112822/ and https://git.eclipse.org/r/#/c/123468/
Besides the junit project, there are two files changed, one is "plugins/org.eclipse.sirius.diagram.ui/src-diag/org/eclipse/sirius/diagram/ui/tools/internal/editor/DDiagramEditorImpl.java", and another is "plugins/org.eclipse.sirius.diagram.ui/src-diag/org/eclipse/sirius/diagram/ui/tools/internal/editor/DDiagramEditorSessionListenerDelegate.java".
Is that true merge these two file changes can fix the memory leak problem? or i need merge other file changes?
If my merge scope is correct, then there still have memory leak on delete project scenario.
My test steps are:
0. Click the "Garbage Collector" icon some times to get the stable heap size.
1. Import a project within a model
2. Create diagrams of this model
3. Open the diagrams
4. Delete the project
5. Repeat step 0 to step 4 for 5 or 10 times
6. Do step 0, to get the stable heap size.
You can see the stable heap size is growing.
Best regards!
by Keep Mind Calm
[Updated on: Tue, 16 October 2018 05:46]
Report message to a moderator
Re: Merge a memory leak defect from Sirius 6.0 to Sirius 4.1.3 [message #1796614 is a reply to message #1796548] Tue, 16 October 2018 13:50 Go to previous messageGo to next message
Pierre Guilet is currently offline Pierre GuiletFriend
I don't reproduce the memory leak with the last Sirius version. You can make a Sirius ticket for this version but it is an old version and we are currently focusing more on the newer.
Except if the ticket is sponsored we cannot guarantee that we will be able to look at it. The other solution is to update your Sirius version.
Pierre Guilet - Obeo
Re: Merge a memory leak defect from Sirius 6.0 to Sirius 4.1.3 [message #1796930 is a reply to message #1796614] Mon, 22 October 2018 14:07 Go to previous messageGo to next message
Member
Hi, Pierre
Thanks for your reply!
It's difficult for us to update Sirius to 6.0, due to we did many specific modifications on version 4.1.3.
I reported a ticket at https://bugs.eclipse.org/bugs/show_bug.cgi?id=540372.
I hope your team can take time on this problem, or just give some guide for this problem.
Best regards!
by Keep Mind Calm
Re: Merge a memory leak defect from Sirius 6.0 to Sirius 4.1.3 [message #1797579 is a reply to message #1796614] Fri, 02 November 2018 09:06 Go to previous message
Member
Hi, Pierre
I tested the eclipse photon with default Sirius version 6.0.0, I found the memory leak exist. And i update Sirius to 6.1.0, leak still exist.
As we know, there are 3 ways to create a diagram.
a) First is initialize all diagrams by select viewpoint (precondition: enable "Initialization" in odesign)
b) Second is "New Representation" menu on explorer tree viewer.
c) Third is "New"-> "Create ****** " menu on a diagram element (if this element can create a diagram).
In my test, test steps as below:
1) Create a empty modeling project
2) Copy a large model into the project. (large model is used for easily recognize the leak.)
3) Select viewpoint, this will initialize all diagrams.
4) Open a diagram
5) Right click a diagram element on the opened diagram, "New"-> "Create ****** " to create a new diagram.
6) Delete the project (delete project contents on disk).
7) Create a empty modeling project
8) Click the "Garbage Collector" icon some times to get the stable heap size.
9) Repeat step 2) to step 8) several times. You will see the heap size grows.
As my experience, execute GC after step 7) can release much more memory than step 6), maybe it is for undo/redo, I'm not sure.
Best regards!
by Keep Mind Calm
[Updated on: Fri, 02 November 2018 09:28]
Previous Topic:How to implement a copy&paste tool on Edit Table
Next Topic:Sequence Diagram in Sirius
Current Time: Sat Feb 27 23:07:44 GMT 2021
Powered by FUDForum. Page generated in 0.02411 seconds
