Home » Eclipse Projects » WindowBuilder » hello. Unable to connect to repository... trying to install windowbuilder(I am trying to install windowbuilder and am unable to connect to repositories / websites with eclipse)
hello. Unable to connect to repository... trying to install windowbuilder [message #1796419] Fri, 12 October 2018 15:27 Go to next message
leon siboldi is currently offline leon siboldiFriend
I am trying to install windowbuilder through the install new software tab in the help section of eclipse. I have tried to manually add and enter the addresses for two different windowbuilder links and have tried connecting to the 2018-19 website. whenever I try to 'work with' a site, I encounter the error
unable to connect to repository.
how do I fix this issue?
Re: hello. Unable to connect to repository... trying to install windowbuilder [message #1796477 is a reply to message #1796419] Sun, 14 October 2018 17:15 Go to previous message
Avi Abrami is currently offline Avi AbramiFriend
I can't tell you how to fix the problem, but if you provide more details then maybe I might be able to.
What error are you getting?
What version of Eclipse did you install?
What platform are you on?
What JDK is installed? Note that you need to install JDK and not JRE.
I use this URL to install WindowBuilder...
http://download.eclipse.org/windowbuilder/latest/
Previous Topic:Oxygen (4.7.2) and WindowBuilder (1.9.1.201710100405)
Next Topic:Incompatible Java Version for WindowBuilder
Current Time: Sat Jan 25 11:25:38 GMT 2020
Powered by FUDForum. Page generated in 0.02189 seconds
