Home » Modeling » TMF (Xtext) » Transient attributes in Xtext grammar (Transient attributes in Xtext grammar )
Transient attributes in Xtext grammar [message #1796227] Mon, 08 October 2018 14:13 Go to next message
Edmundo López Bóbeda is currently offline Edmundo López BóbedaFriend
I have a DSL where I'm generating the Ecore meta model from from the Xtext grammar.
Due to a feature request I needed to add a transient volatile attribute in the generated metamodel and implement it in the generated code.
Is there a way to define this directly in the Xtext grammar, so that I can continue to generate everything (including the ecore model) from the Xtext grammar?
Thanks in advance for your help.
Re: Transient attributes in Xtext grammar [message #1796229 is a reply to message #1796227] Mon, 08 October 2018 14:20 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
no
- you need either switch to a manually maintained metamodel
- or use the workarounds you can find using google to use IXtext2EcorePostProcessor with the new workflow e.g. https://bugs.eclipse.org/bugs/show_bug.cgi?id=483209
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Transient attributes in Xtext grammar [message #1796235 is a reply to message #1796229] Mon, 08 October 2018 15:40 Go to previous message
Thank you, I'll look into the IXtext2EcorePostProcessor.
Previous Topic:Is it possible to write Grammar in more than one Xtext file?
Next Topic:Using Formatter2
Current Time: Sun Sep 25 00:22:35 GMT 2022
Powered by FUDForum. Page generated in 0.02393 seconds
