Re: Annotation processing with Java 11 Support Plug-in [message #1799953 is a reply to message #1799947] |
Mon, 17 December 2018 23:03 |
Cristiano Gavião Messages: 279 Registered: July 2009 |
Hello Ed,
I found where the problem was apparently.
I'm using ubuntu and I was with oracle jdk 8 installed when I installed 2018-12 rc1 IDE using Oomph.
When I did install it I selected the java8 in OOMPH UI combo box, so it fixed java8 path in the -vm argument on eclipse.ini file: Quote: > -vm /usr/lib/jvm/java-8-oracle/bin
In the same day I have installed the jdk 11 and choose it as default, but kept the jdk8.
Now I've installed a new 2018-12 but unselected the oomph task that fix the -vm.
So this installation doesn't have the -vm argument anymore, so I'm not getting the error I got with the other installation.
[Updated on: Mon, 17 December 2018 23:04] Report message to a moderator
FUDForum. Page generated in 0.03238 seconds
