Re: Xtext Generator making random mistakes while generating java classes [message #1796044 is a reply to message #1796043] |
Thu, 04 October 2018 12:24 |
Mehmetcan Sinir Messages: 55 Registered: September 2018 |
Member |
also here is for reference:
Build.gradle of the parent project
buildscript {
repositories {
jcenter()
maven {
url "https://plugins.gradle.org/m2/"
dependencies {
classpath 'org.xtext:xtext-gradle-plugin:1.0.21'
classpath 'com.moowork.gradle:gradle-node-plugin:1.2.0'
classpath 'net.researchgate:gradle-release:2.6.0'
apply plugin: 'net.researchgate.release'
apply plugin: 'com.moowork.node'
node {
version = '8.11.1'
npmVersion = '5.6.0'
download = true
configure(subprojects.findAll { it.name.startsWith('de.bmw') }) {
ext.xtextVersion = '2.14.0'
repositories {
maven {
url 'https://oss.sonatype.org/content/repositories/snapshots'
jcenter()
apply plugin: 'java'
apply plugin: 'org.xtext.xtend'
apply from: "${rootDir}/gradle/source-layout.gradle"
apply from: "${rootDir}/gradle/maven-deployment.gradle"
apply plugin: 'eclipse'
apply plugin: 'idea'
group = 'de.bmw.rhmi'
version = '1.0.0-SNAPSHOT'
sourceCompatibility = '1.8'
targetCompatibility = '1.8'
configurations.all {
exclude group: 'asm'
task npmInstallVsce(type: NpmTask, dependsOn: npmSetup) {
ext.destPath = "$rootProject.projectDir/node_modules/vsce"
outputs.dir(destPath)
group 'Node'
description 'Installs the NodeJS package "Visual Studio Code Extension Manager"'
args = [ 'install', 'vsce' ]
// Configuration for vscode projects
configure(subprojects.findAll { it.name.startsWith('vscode') }) {
node {
version = '6.11.3'
npmVersion = '3.10.10'
download = true
def inputFiles = fileTree(
dir: projectDir,
excludes: [ 'out/**', '.gitignore', '.gradle/**', 'build/**', '*.gradle' ]
npmInstall {
inputs.files(inputFiles)
outputs.dir('out')
//this task creates the vscode-extension-self-contained-0.0.14.visx file
task vscodeExtension(dependsOn: [npmInstall, npmInstallVsce], type: NodeTask) {
//set the destination directory
ext.destDir = new File(buildDir, 'vscode')
//set the archive name
ext.archiveName = "$project.name-${project.version}.vsix"
//set the destination path
ext.destPath = "$destDir/$archiveName"
inputs.with {
files inputFiles
dir npmInstallVsce.destPath
outputs.dir destDir
doFirst {
destDir.mkdirs()
script = file("$npmInstallVsce.destPath/out/vsce")
args = [ 'package', '--out', destPath ]
execOverrides {
workingDir = projectDir
task clean {
doLast {
delete vscodeExtension.destDir
delete 'out' // output of npmInstall - don't want to delete node_modules
// Workaround for issue https://github.com/researchgate/gradle-release/issues/144
task build {
dependsOn subprojects.findResults { it.tasks.findByName('build') }
build.gradle of the sub project where the grammer is defined
dependencies {
testCompile "junit:junit:4.12"
testCompile "org.eclipse.xtext:org.eclipse.xtext.testing:${xtextVersion}"
testCompile "org.eclipse.xtext:org.eclipse.xtext.xbase.testing:${xtextVersion}"
compile "org.eclipse.xtext:org.eclipse.xtext:${xtextVersion}"
compile "org.eclipse.xtext:org.eclipse.xtext.xbase:${xtextVersion}"
compile group: 'org.eclipse.emf', name: 'org.eclipse.emf.mwe2.launch', version: '2.9.1.201705291010'
compile group: 'org.eclipse.core', name: 'org.eclipse.core.resources', version: '3.7.100'
compile group: 'xom', name: 'xom', version: '1.2.5'
compile group: 'javax.xml.bind', name: 'jaxb-api', version: '2.2.5'
compile group: 'com.sun.xml.bind', name: 'jaxb-impl', version: '2.2.5'
configurations {
mwe2 {
extendsFrom compile
dependencies {
compile project(':de.bmw.rhmi.resource')
mwe2 "org.eclipse.emf:org.eclipse.emf.mwe2.launch:2.9.1.201705291010"
mwe2 "org.eclipse.xtext:org.eclipse.xtext.common.types:${xtextVersion}"
mwe2 "org.eclipse.xtext:org.eclipse.xtext.xtext.generator:${xtextVersion}"
mwe2 "org.eclipse.xtext:xtext-antlr-generator:[2.1.1, 3)"
task generateXtextLanguage(type: JavaExec) {
main = 'org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher'
classpath = configurations.mwe2
inputs.file "src/main/java/de/bmw/rhmi/GenerateHmi.mwe2"
inputs.file "src/main/java/de/bmw/rhmi/Hmi.xtext"
outputs.dir "src/main/xtext-gen"
args += "src/main/java/de/bmw/rhmi/GenerateHmi.mwe2"
args += "-p"
args += "rootPath=/${projectDir}/.."
generateXtext.dependsOn(generateXtextLanguage)
clean.dependsOn(cleanGenerateXtextLanguage)
eclipse.classpath.plusConfigurations += [configurations.mwe2]
I am trying to build a VSCode extension
Re: Xtext Generator making random mistakes while generating java classes [message #1796060 is a reply to message #1796055] |
Thu, 04 October 2018 15:19 |
Member |
Ed Willink wrote on Thu, 04 October 2018 13:46Hi
Your original report suggested a regular problem, so it is unlikely to be associated with a manual activity. I suspect that for some reason multiple builds run from a single trigger. Possibly due to multiple registered (platform) builders/natures, possibly due to multiple EF Generators. Perhaps some EMF-based project that I am not familiar with auto-builds from genmodels.
In your position I would instrument XMIResourceImpl.save(*) to get some insight into the multiples.
Ed Willink
@Ed Willink
How do I do that exactly?
Here is the interesting parts of the console output when I run the builder.
1207 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator [b][/b]
1894 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
5283 [main] INFO text.xtext.generator.XtextGenerator - Generating de.bmw.rhmi.App
8578 [main] INFO nerator.ecore.EMFGeneratorFragment2 - Generating EMF model code
8635 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.bmw.de/rhmi/app' from 'platform:/resource/de.bmw.rhmi/model/generated/App.genmodel'
14550 [main] INFO text.xtext.generator.XtextGenerator - Generating de.bmw.rhmi.Hmi
32123 [main] INFO nerator.ecore.EMFGeneratorFragment2 - Generating EMF model code
32203 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.bmw.de/rhmi/hmi' from 'platform:/resource/de.bmw.rhmi/model/generated/Hmi.genmodel'
103360 [main] INFO text.xtext.generator.XtextGenerator - Generating common infrastructure
103362 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Can I run the mwe2 workflow through the console and with a debug option so that I know what is going on exactly?
Something is definitely wrong.
For example here is part of the InternalHmiParser.java class which is also generated and which is a complete code mish mash:
try {
// InternalHmi.g:24073:2: ( ( ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) ) ) )
// InternalHmi.g:24074:2: ( ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) ) )
// InternalHmi.g:24075:3: ( (lv_value_0_0= ruleIntLiteral ) ) (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) )
// InternalHmi.g:24076:4: (lv_value_0_0= ruleIntLiteral )
// InternalHmi.g:24077:5: lv_value_0_0= ruleIntLiteral
newCompositeNode(grammarAccess.getTableLayoutValueAccess().getValueIntLiteralParserRuleCall_0_0());
pushFollow(FollowSets000.FOLLOW_123);
lv_value_0_0=ruleIntLiteral();
state._fsp--;
if (current==null) {
current = createModelElementForParent(grammarAccess.getTableLayoutValueRule());
add(
current,
"value",
lv_value_0_0,
"de.bmw.rhmi.Hmi.IntLiteral");
afterParserOrEnumRuleCall();
// InternalHmi.g:24094:3: (otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) ) )
// InternalHmi.g:24095:4: otherlv_1= ',' ( (lv_value_2_0= ruleIntLiteral ) )
otherlv_1=(Token)match(input,71,FollowSets000.FOLLOW_25);
newLeafNode(otherlv_1, grammarAccess.getTableLayoutValueAccess().getCommaKeyword_1_0());
// InternalHmi.g:24099:4: ( (lv_value_2_0= ruleIntLiteral ) )
// InternalHmi.g:24100:5: (lv_value_2_0= ruleIntLiteral )
// InternalHmi.g:24101:6: lv_value_2_0= ruleIntLiteral
newCompositeNode(grammarAccess.getTableLayoutValueAccess().getValueIntLiteralParserRuleCall_1_1_0());
pushFollow(FollowSets000.FOLLOW_2);
lv_value_2_0=ruleIntLiteral();
state._fsp--;
add(
current,
"value",
lv_value_2_0,
leaveRule();
catch (RecognitionException re) {
recover(input,re);
appendSkippedTokens();
FUDForum. Page generated in 0.03734 seconds
