Re: Start up error [message #1795891 is a reply to message #1795887] |
Tue, 02 October 2018 03:07 |
Do you have any technical details you can share, like how you installed Eclipse, which version it is,
where it was installed, or what version of Java you're running? Right now this looks like
an old version of Eclipse with a very new version of Java, but that's a total guess.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Tue, 02 October 2018 03:08] Report message to a moderator
Re: Start up error [message #1796088 is a reply to message #1796087] |
Fri, 05 October 2018 03:34 |
Kasheem Stroman Messages: 6 Registered: October 2018 |
!SESSION 2018-09-30 12:08:08.194 -----------------------------------------------
eclipse.buildId=4.9.0.I20180906-0745
java.version=1.8.0_192-ea
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2018-09-30 12:10:38.059
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\pc'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!SESSION 2018-09-30 12:31:18.357 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -data file:/C:/Users/pc/eclipse-workspace/ -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.ui 2 0 2018-09-30 12:31:53.391
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-10-01 13:21:28.970
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.util.concurrent.TimeoutException: Timed out waiting for org.eclipse.epp.logging.aeri.ide.server ServerConnection [STOPPING] to reach a terminal state. Current state: STOPPING
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:479)
at org.eclipse.osgi.container.Module.doStop(Module.java:637)
at org.eclipse.osgi.container.Module.stop(Module.java:501)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:205)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213)
Caused by: java.util.concurrent.TimeoutException: Timed out waiting for org.eclipse.epp.logging.aeri.ide.server ServerConnection [STOPPING] to reach a terminal state. Current state: STOPPING
at com.google.common.util.concurrent.AbstractService.awaitTerminated(AbstractService.java:317)
at com.google.common.util.concurrent.AbstractIdleService.awaitTerminated(AbstractIdleService.java:199)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.ServerConnection.diStop(ServerConnection.java:392)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 25 more
!SESSION 2018-10-01 16:54:22.278 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:55:12.194
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (98).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:803)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:732)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1005)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:357)
at org.eclipse.osgi.container.Module.doStart(Module.java:584)
at org.eclipse.osgi.container.Module.start(Module.java:452)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:471)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:557)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:331)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:39)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:156)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:62)
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:70)
at org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1042)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:705)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1561)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2451)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2208)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:489)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:782)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:775)
... 29 more
Caused by: java.lang.Exception: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:42)
at org.eclipse.core.internal.resources.ResourceException.<init>(ResourceException.java:38)
... 41 more
Root exception:
org.eclipse.core.internal.resources.ResourceException(null)[567]: java.lang.Exception: Incompatible file format. Workspace was saved with an incompatible version: 0.
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:55:12.503
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (98).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:56:37.168 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:56:44.728
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:56:44.856
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:58:14.976 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:22.385
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:22.465
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 16:58:34.407 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:43.397
!STACK 0
... 29 more
... 41 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2018-10-01 16:58:43.493
!STACK 1
... 13 more
... 22 more
... 29 more
... 41 more
!SESSION 2018-10-01 17:03:13.868 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2018-10-01 17:04:11.040
!STACK 0
FUDForum. Page generated in 0.09133 seconds
