Home » Eclipse Projects » Sirius » Error saving diagram (error detecting the change *)
Error saving diagram (error detecting the change *) [message #1795736] Thu, 27 September 2018 14:07 Go to next message
Pratiksha Dalal is currently offline Pratiksha DalalFriend
Hello all,
I'm facing similar issue as that of https://www.eclipse.org/forums/index.php/t/1069136/. But the issue is not consistent. Sometimes it saves and sometimes it doesn't :(
Here is the environment:
* Eclipse Photon 4.9
* Java 1.8.0
* Sirius 6.0.1
* Metamodel: plain ecore
Can somebody help please? Large amount of my day's work is not being saved and its quite annoying..
Pratiksha
Re: Error saving diagram (error detecting the change *) [message #1795739 is a reply to message #1795736] Thu, 27 September 2018 14:36 Go to previous messageGo to next message
Jessy Mallet is currently offline Jessy MalletFriend
Hi Pratiksha,
We can not reproduce your problem with such information. We need more precisions please.
Are icons to save disabled in your case? If not, do they throw errors when invoked?
Re: Error saving diagram (error detecting the change *) [message #1796108 is a reply to message #1795739] Fri, 05 October 2018 08:51 Go to previous messageGo to next message
Save and Save as are not enabled
And even if change is detected (astrick sign is there) changes will be reverted back after saving
Re: Error saving diagram (error detecting the change *) [message #1796225 is a reply to message #1796108] Mon, 08 October 2018 13:54 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Could you give us more info on your environment : build id number and version (from about Eclipse), version of java.
How did you install Sirius ?
When you hit CTRL+S does it save the changes ?
Maxime Porhel - Obeo
Join the Sirius community at SiriusCon. Register for free: Nov. 9th Paris
http://www.siriuscon.org/
Re: Error saving diagram (error detecting the change *) [message #1806021 is a reply to message #1796225] Tue, 30 April 2019 15:12 Go to previous message
First of all Sorry I missed the reply.
Sirius build id is : 6.0.1.201808231529
Java Version : "1.8.0_181"
For installing Sirius I go to Help of Sirius and install new software where I give link http://download.eclipse.org/sirius/updates/releases/6.0.1/photon and install.
No ctrl+s does not save the changes.
Me and my team is facing this issue alot they configure alot of things for the whole day and they lost it the other day.
Its becoming very hard to work like this.
Please help me with this issue.
Previous Topic:Change context before navigation
Next Topic:SWTBot for sirius properties
Current Time: Mon Jan 20 03:15:59 GMT 2020
Powered by FUDForum. Page generated in 0.01724 seconds
