Re: product catalog occurrenceIndicationColor [message #1795696 is a reply to message #1795578] |
Thu, 27 September 2018 03:35   |
Ed Merks Messages: 31709 Registered: July 2009 |
Marcus, how did you create the preference task?
The easiest way to create a preference task is to use the Record Preferences toolbar button while editing your *.setup. But I'm not sure where you find this specific preference, occurrenceIndicationColor , in the dialog. A related one for JDT's write access occurrences would look like this:<?xml version="1.0" encoding="UTF-8"?>
<setup:CompoundTask
xmi:version="2.0"
xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
name="org.eclipse.ui.workbench">
<setupTask
xsi:type="setup:PreferenceTask"
key="/instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.ColoredLabels.writeaccess_highlight"
value="237,208,150"/>
</setup:CompoundTask>
Yes, documentation could be improved, but more often than not, people don't read it anyway, even if its presented to them directly in the IDE's help...
Ed Merks
FUDForum. Page generated in 0.02773 seconds
