Home » Language IDEs » Java Development Tools (JDT) » Turn off formatter for commented lines(Eclipse change settings)
Turn off formatter for commented lines [message #1795485] Mon, 24 September 2018 03:52 Go to next message
Is there a way to turn off the formatter only for commented lines?
1. Example code:
int number = 10;
number = 11;
2. Code after selecting it and using Ctrl + Shift + / to comment it:
/*int number = 10;
number = 11;*/
3. Code after using auto-format Ctrl + Shift + F:
* int number = 10; number = 11;
4. Code after selecting it and using Ctrl + Shift + \ to uncomment it:
It will remove /* and */ from start and end of the code, but it will leave * behind at the start of each line.
Is there a way to stop the auto-format from turning the code from 2. into 3.? Or even after the auto-format does that change, to make the Ctrl + Shift + \ remove the * from each line?
Re: Turn off formatter for commented lines [message #1795758 is a reply to message #1795485] Fri, 28 September 2018 02:20 Go to previous message
Have a look at Window -> Preferences -> Java -> Code Style -> Formatter, edit those, and look at the Comments section where you can disable block comment formatting.
Previous Topic:Different behaviour when generating hashCode and equals
Next Topic: Invalid Property Category Path Error
Current Time: Sat Jul 19 05:42:38 EDT 2025
Powered by FUDForum. Page generated in 0.08917 seconds
