Home » Eclipse Projects » Oomph » Stream is unresolved
Stream is unresolved [message #1795377] Fri, 21 September 2018 06:16 Go to next message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I've a setup configuration which points to a setup file within a Git repo. The setup editor complaints about "unresolved stream":
The feature 'streams' of ' Fakturama IDE Workspace' contains an unresolved proxy ' https://bitbucket.org/fakturamadev/fakturama-2/raw/develop/Fakturama-Parent/com.sebulli.fakturama.rcp/project/Fakturama2GIT.setup#//@streams[name='release/2.0.3']'
If I try to choose the stream from the selection dialog I can't find the right entry (which should be my project, I think). If I set this entry manually to a (valid) local file the setup editor is ok. Now I don't know how to set the correct stream. Could you please give me a hint?
TIA,
Ralf.
Re: Stream is unresolved [message #1795380 is a reply to message #1795377] Fri, 21 September 2018 07:00 Go to previous messageGo to next message
I found it by myself. At first, the stream name wasn't corresponding with the stream name in the other file. And secondly the URL to the setup file wasn't correct. Now this works.
Ralf.
Re: Stream is unresolved [message #1795382 is a reply to message #1795380] Fri, 21 September 2018 07:11 Go to previous messageGo to next message
You only have a stream named 'master' but none named 'release/2.0.3' so you'll need to update your configuration to point at the correct stream.
Re: Stream is unresolved [message #1795468 is a reply to message #1795382] Sun, 23 September 2018 18:46 Go to previous message
ok, thanks. I'll update my config.
Ralf.
Previous Topic:Target URI is not well formed
Next Topic:Oomph complains about unsatisfied requirements after update
Current Time: Fri Jul 10 20:35:22 GMT 2020
Powered by FUDForum. Page generated in 0.02241 seconds
