Home » Modeling » TMF (Xtext) » Xtext 2.15.0 released!
Xtext 2.15.0 released! [message #1795283] Wed, 19 September 2018 20:05 Go to next message
Karsten Thoms is currently offline Karsten ThomsFriend
The Eclipse Xtext team is happy to announce version 2.15.0, which is also part of the Eclipse 2018-09 simultaneous release.
With this release, Xtext focussed again on stability & performance, and is the first release that takes part in the new quarterly rolling Eclipse release train. This has been a challenge to keep up the fast release cycle, but we are prepared now to ship also Xtext more frequently.
Read the detailed description of this release in the Xtext 2.15 Release Notes and get Xtext either from the Eclipse 2018-09 Composite Release Update Site or from the Xtext 2.15.0 Release Update Site.
Thank you for choosing Xtext!
~Karsten
- on behalf of the Eclipse Xtext Team -
Need professional support for Xtext, EMF, Eclipse IDE?
Go to: http://devhub.karakun.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
Re: Xtext 2.15.0 released! [message #1796448 is a reply to message #1795283] Sat, 13 October 2018 09:19 Go to previous messageGo to next message
Alex Mising name is currently offline Alex Mising nameFriend
After installing this I get the following exception when I try to launch the generator (org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher):
Error: A JNI error has occurred, please check your installation and try again
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/cli/ParseException
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2701)
	at java.lang.Class.privateGetMethodRecursive(Class.java:3048)
	at java.lang.Class.getMethod0(Class.java:3018)
	at java.lang.Class.getMethod(Class.java:1784)
	at sun.launcher.LauncherHelper.validateMainClass(LauncherHelper.java:544)
	at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:526)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.cli.ParseException
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 7 more
This is on the default-generated Xtext project.
Has something changed in the packaging? I use P2 director to create my installation using the following 2 features:
  • org.eclipse.xtext.sdk.feature.group
  • org.eclipse.xtend.sdk.feature.group
Re: Xtext 2.15.0 released! [message #1796449 is a reply to message #1796448] Sat, 13 October 2018 09:34 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i dont know of any change. can you please open a issue at
github.com/eclipse/xtext-umbrella with steps how to reproduce/what you are doing.
you can find commons cli here:
http://download.eclipse.org/tools/orbit/downloads/drops/R20180905201904/
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Xtext 2.15.0 released! [message #1796450 is a reply to message #1796449] Sat, 13 October 2018 09:38 Go to previous messageGo to next message
p.s.: where do you install mwe from. which mwe features do you install?
Re: Xtext 2.15.0 released! [message #1796451 is a reply to message #1796449] Sat, 13 October 2018 09:45 Go to previous messageGo to next message
I rely on dependencies to let Xtext feature pull in whatever it likes.
There are 2 factors here:
1. This is not a "standard" distribution but rather one created using P2 director (org.eclipse.equinox.p2.director)
2. I use a UK mirror to install (https://www.mirrorservice.org/sites/download.eclipse.org/eclipseMirror/releases/2018-09)
I will disable the mirror in case it is broken and if it persists, I will start incrementally adding plugins (the script pulls several things in addition to xtext/xtend, maybe something does not play nice with it).
If it persists I will open a bug.
Regarding MWE2, looking at the installation details I see it was pulled as a dependency of the Xtext Complete SDK feature:
org.eclipse.emf.mwe2.language.sdk.feature.group
2.9.1.201705291011
Re: Xtext 2.15.0 released! [message #1796453 is a reply to message #1796451] Sat, 13 October 2018 09:48 Go to previous messageGo to next message
which version where you using before? did you change only xtext or did you change eclipse/platform/jdt as well?
Re: Xtext 2.15.0 released! [message #1796454 is a reply to message #1796453] Sat, 13 October 2018 09:52 Go to previous messageGo to next message
the org.eclipse.emf.mwe2.language.sdk includes
org.eclipse.emf.mwe2.launcher feature that has:
<import plugin="org.apache.commons.cli"/>
and
org.eclipse.emf.mwe.sdk has
<includes
id="org.eclipse.emf.mwe.core.feature"
version="0.0.0"/>
which includes the plugin
so maybe you should install that as well
Re: Xtext 2.15.0 released! [message #1796455 is a reply to message #1796453] Sat, 13 October 2018 09:53 Go to previous message
So, this is the reason I use a script. I run 1 command and it creates a new installation from scratch with all plugins I use (JDT, CDT, Xtext, Xtend, EclEmma, FindBugs, DevStyle dark theme, etc etc)
So when my script runs it creates a "fresh" 2018-09" installation with the following:
Installing org.eclipse.platform.ide 4.9.0.I20180906-0745.
Installing org.eclipse.jdt.feature.group 3.15.0.v20180906-0745.
Installing org.eclipse.cdt.feature.group 9.5.4.201810050005.
Installing org.eclipse.m2e.feature.feature.group 1.9.1.20180912-1601.
Installing org.eclipse.m2e.logback.feature.feature.group 1.9.1.20180912-1601.
Installing org.eclipse.egit.feature.group 5.1.0.201809111528-r.
Installing org.eclipse.xtext.sdk.feature.group 2.15.0.v20180916-1232.
Installing org.eclipse.xtend.sdk.feature.group 2.15.0.v20180916-1232.
Installing org.eclipse.datatools.sdk.feature.feature.group 1.14.101.201807022034.
Installing org.eclipse.eclemma.feature.feature.group 3.1.1.201809121651.
Installing edu.umd.cs.findbugs.plugin.eclipse.feature.group 3.0.1.20150306-5afe4d1.
Installing net.jeeeyul.eclipse.themes.feature.feature.group 2.3.1.I20180720-143135.
Installing org.eclipse.buildship.feature.group 2.2.2.v20181003-1021.
Installing org.sonatype.tycho.m2e.feature.feature.group 0.9.0.201609252021.
Installing com.genuitec.eclipse.theming.feature.feature.group 1.11.0.201809241613.
Installing cucumber.eclipse.feature.feature.group 0.0.22.201806032001.
I have now removed all non-core stuff (i.e. only install the below) and the problem is fixed. So it seems like some other plugin is causing some sort of collision. Will add them gradually and may end up chasing up on that side...
Installing org.eclipse.cdt.feature.group 9.5.3.201809121146.
Previous Topic:Variable reference error
Next Topic:Example for Semantic Refactoring
Current Time: Mon Oct 03 05:18:58 GMT 2022
Powered by FUDForum. Page generated in 0.02363 seconds
