Home » Eclipse Projects » Sirius » Hidding double links
Hidding double links [message #1795215] Tue, 18 September 2018 13:59 Go to next message
David CHARLET is currently offline David CHARLETFriend
In my model, objects have a list of child. Each child knows who is his father.
For instance in the pic attached, if object A has B as a child then A is also B's child.
I would like to either hide one link or merge both into one without touching my model.
https://www.eclipse.org/forums/index.php?t=getfile&id=33905&http://
Is there any simple trick to achieve that ?
  • Attachment: pp.png
    (Size: 5.55KB, Downloaded 186 times)
[Updated on: Tue, 18 September 2018 14:01]
Report message to a moderator
Re: Hidding double links [message #1795218 is a reply to message #1795215] Tue, 18 September 2018 14:24 Go to previous messageGo to next message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
To achieve what you want you need to differanciate the feature child and the feature parent(I guess it is what you did). Indeed, it has ne sense to tell that A is a child of B and B is a child of A.
Then you just have do define a Relation Based Edge mapping that is either the child or the parent feature.
Laurent
Laurent Fasani - Obeo
Re: Hidding double links [message #1795219 is a reply to message #1795218] Tue, 18 September 2018 14:40 Go to previous message
I made a mistake it's not a parent/child relationship but rather like a friendship. A is friend with B so B is friend with A.
What I have :
https://www.eclipse.org/forums/index.php?t=getfile&id=33906&
What i expect :
https://www.eclipse.org/forums/index.php?t=getfile&id=33907&
  • Attachment: have.png
    (Size: 4.94KB, Downloaded 116 times)
  • Attachment: expectation.png
    (Size: 4.52KB, Downloaded 109 times)
[Updated on: Tue, 18 September 2018 14:41]
Previous Topic:Turn grey a sub menu instead of hiding it
Next Topic:InstanceRole with port-like decoration
Current Time: Wed Feb 24 23:57:12 GMT 2021
Powered by FUDForum. Page generated in 0.02061 seconds
