Home » Modeling » Eclipse Layout Kernel » 'UnsupportedConfigurationException' after closing alg.layered.
'UnsupportedConfigurationException' after closing alg.layered. [message #1795075] Fri, 14 September 2018 06:44 Go to next message
zhang ph is currently offline zhang phFriend
Member
I use the ELK to layout my diagram in sirius editor. In my odesign, I set the layout algorithm as "ELK Mr. Tree" and I uninstall the "ELK Layered" from my eclipse, when I perform arrange all in sirius editor, there is exception appears as follows:
Sirius version: 6.0.1
ELK version: 0.4.1
Test model: family sample
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:496)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:71)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:52)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.execute(DiagramAction.java:141)
at org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doRun(DiagramAction.java:103)
at org.eclipse.gmf.runtime.diagram.ui.actions.internal.ArrangeAction.doRun(ArrangeAction.java:278)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:359)
at org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run(ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:71)
at org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(ActionManager.java:223)
at org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.runWithEvent(AbstractActionHandler.java:377)
at org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetAction.java:226)
at org.eclipse.gmf.runtime.common.ui.action.ActionMenuManager$MenuCreatorAction.runWithEvent(ActionMenuManager.java:216)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Caused by: org.eclipse.elk.core.UnsupportedConfigurationException: No layout algorithm has been specified for Root Node > Node Paul
at org.eclipse.elk.core.data.LayoutAlgorithmResolver.resolveAlgorithm(LayoutAlgorithmResolver.java:45)
at org.eclipse.elk.core.data.LayoutAlgorithmResolver.visit(LayoutAlgorithmResolver.java:26)
at org.eclipse.elk.core.util.ElkUtil.applyVisitors(ElkUtil.java:860)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:72)
at org.eclipse.sirius.diagram.elk.ElkDiagramLayoutConnector.layout(ElkDiagramLayoutConnector.java:1167)
at org.eclipse.sirius.diagram.elk.ELKLayoutNodeProvider.layoutEditParts(ELKLayoutNodeProvider.java:37)
at org.eclipse.sirius.diagram.ui.tools.internal.layout.provider.ArrangeSelectionLayoutProvider.lauchPrimaryArrangeAll(ArrangeSelectionLayoutProvider.java:255)
at org.eclipse.sirius.diagram.ui.tools.internal.layout.provider.ArrangeSelectionLayoutProvider.layoutEditParts(ArrangeSelectionLayoutProvider.java:171)
at org.eclipse.sirius.diagram.ui.tools.api.layout.provider.AbstractLayoutProvider.getCommandFromDiagramLayoutProvider(AbstractLayoutProvider.java:168)
at org.eclipse.sirius.diagram.ui.tools.api.layout.provider.AbstractLayoutProvider.layoutEditParts(AbstractLayoutProvider.java:117)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.AbstractLayoutEditPartProvider.layoutLayoutNodes(AbstractLayoutEditPartProvider.java:69)
at org.eclipse.gmf.runtime.diagram.ui.internal.services.layout.LayoutNodesOperation.execute(LayoutNodesOperation.java:74)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$1.execute(ExecutionStrategy.java:70)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.execute(LayoutService.java:66)
at org.eclipse.gmf.runtime.diagram.ui.services.layout.LayoutService.layoutLayoutNodes(LayoutService.java:299)
at org.eclipse.gmf.runtime.diagram.ui.commands.ArrangeCommand.getCommandForExecution(ArrangeCommand.java:124)
at org.eclipse.gmf.runtime.diagram.ui.commands.ArrangeCommand.doExecuteWithResult(ArrangeCommand.java:93)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.emf.workspace.CompositeEMFOperation.doExecute(CompositeEMFOperation.java:217)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:123)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:488)
... 41 more
Hope for your reply!!!
[Updated on: Fri, 14 September 2018 06:53]
Report message to a moderator
Re: 'UnsupportedConfigurationException' after closing alg.layered. [message #1795090 is a reply to message #1795075] Fri, 14 September 2018 10:11 Go to previous messageGo to next message
Christoph Daniel Schulze is currently offline Christoph Daniel SchulzeFriend
Member
Hi there,
the problem here seems to be the following. You don't seem to set Mr. Tree as the layout algorithm on all of your nodes. If no layout algorithm is set, ELK defaults to ELK Layered, which, as you said, you uninstalled. The default algorithm can thus not be resolved, hence the exception.
The solution is to set Mr. Tree on all nodes that contain further nodes themselves. You shouldn't be uninstalling layout algorithms.
Chris
Re: 'UnsupportedConfigurationException' after closing alg.layered. [message #1795092 is a reply to message #1795090] Fri, 14 September 2018 10:58 Go to previous messageGo to next message
Member
In my application, I only want to install one specific algorithm(like Mr. Tree), Currently it may be set on the top node instead of all nodes, Is there a convenient way to set it to all nodes?
[Updated on: Fri, 14 September 2018 11:16]
Re: 'UnsupportedConfigurationException' after closing alg.layered. [message #1795109 is a reply to message #1795092] Fri, 14 September 2018 18:06 Go to previous message
Member
are you simply using the Sirius-based editor or are you its developer?
Chris
Previous Topic:ELK and Sirius "Arrange All"?
Next Topic:[ELK] Does ELK support this feature an edge out goes and in comes to the same port?
Current Time: Fri Dec 08 13:37:32 GMT 2023
Powered by FUDForum. Page generated in 0.01924 seconds
