Operator == with null operand [message #1795053] |
Thu, 13 September 2018 15:53 |
Dear all.
I have defined several extension methods (which are implicitly imported):
def boolean operator_equals(AtomicLong left, int right) {}
def boolean operator_equals(AtomicLong left, short right) {}
def boolean operator_equals(AtomicLong left, long right) {}
def boolean operator_equals(AtomicLong left, float right) {}
def boolean operator_equals(AtomicLong left, double right) {}
def boolean operator_equals(AtomicLong left, byte right) {}
def boolean operator_equals(AtomicLong left, Number right) {}
def boolean operator_equals(AtomicInteger left, int right) {}
def boolean operator_equals(AtomicInteger left, short right) {}
def boolean operator_equals(AtomicInteger left, long right) {}
def boolean operator_equals(AtomicInteger left, float right) {}
def boolean operator_equals(AtomicInteger left, double right) {}
def boolean operator_equals(AtomicInteger left, byte right) {}
def boolean operator_equals(AtomicInteger left, Number right) {}
The following line is compiled without error:
def void fct(AtomicInteger value) {
if (value == null) {
But the following line causes a compilation error (ambiguous feature call):
if (null == value) {
As you could see, the operands of the == operator are switched.
Semantically, both definitions are equivalent.
My question is: what is the best way to support the failing case?
Is possible to define an operator_equals function and specifying that this function is usable when the left argument is null?
Should I define operator_equals(Object left, Number right)? In this case, the type compiler of Xbase hould be fixed to avoid the ambiguous feature call error.
What do you think?
All the best.
Stéphane.
FUDForum. Page generated in 0.03525 seconds
