Home » Modeling » Papyrus » Bug in Sequence Diagram(After deletion of a message on a lifeline)
Bug in Sequence Diagram [message #1794945] Tue, 11 September 2018 13:01 Go to next message
Yoann Farré is currently offline Yoann FarréFriend
I probably have detected a bug in the sequence diagram (in Nightly Papyrus Photon build : 4.1.0.2018091102)
To reproduce the bug:
- Create a sequence diagram in a papyrus model
- Add a lifeline in the interaction
- Trace an Async Message (source and target on the same Lifeline)
- Delete the message (Delete key or Delete Selected Element)
Result: The message is well deleted in the model but is still displayed on the diagram. The figure (of the message) is no more related to any model element and can only be erased thanks to close/open the diagram. And even after that, I can't select the lifeline or add other elements to the diagram...
Can someone try to reproduce this bug?
Yoann.
Re: Bug in Sequence Diagram [message #1794948 is a reply to message #1794945] Tue, 11 September 2018 13:45 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick TessierFriend
Hi Yoann,
When we have done manual test campaign, we have not remark this bugs.
Our Junit tests do not reveal this bug.
Have you only install papyrus? have you add model transformation module on this.
f someone has also remark this bug, you are welcome. If it is raised we will add a bug and consider as an important bug to solve.
Papyrus Team
Re: Bug in Sequence Diagram [message #1794953 is a reply to message #1794948] Tue, 11 September 2018 14:37 Go to previous messageGo to next message
Hi Patrick,
Thank you for your reply.
In addition, Papyrus Software Designer, Moka, and some plugins I developped are installed on the Eclipse target. But I reproduced this bug on several instances of Eclipse (Photon Last Release and Photon Nightly) and in a very basic Papyrus model containing only the elements I described in my first post on this thread. The transformation modules I used are not involved in this example.
Yoann.
Re: Bug in Sequence Diagram [message #1794957 is a reply to message #1794953] Tue, 11 September 2018 15:03 Go to previous messageGo to next message
Ok, So we wil test with Papyrus Software Designer, Moka to see if we have not a border effect .
Patrick
Re: Bug in Sequence Diagram [message #1794984 is a reply to message #1794957] Wed, 12 September 2018 08:27 Go to previous messageGo to next message
For information, I just did a fresh install of Papyrus (RCP Weekly Photon (4.1.0) nightly) without any additionnal component and I can reproduce the same behavior that described in the first post. So it's probably not a border effect.
Yoann.
Re: Bug in Sequence Diagram [message #1795047 is a reply to message #1794984] Thu, 13 September 2018 13:40 Go to previous messageGo to next message
Nicolas FAUVERGUE is currently offline Nicolas FAUVERGUEFriend
Member
Hi Yoann,
I tried to reproduce many times this bug and i can reproduce this one but not all the time.
I created a bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=539026 and i'm actually working on the solution.
BR,
Nicolas
Re: Bug in Sequence Diagram [message #1795076 is a reply to message #1795047] Fri, 14 September 2018 06:57 Go to previous messageGo to next message
Hello Nicolas,
Thank you. If I have any useful information, I'll add it in the bug tracker.
Yoann
Re: Bug in Sequence Diagram [message #1795149 is a reply to message #1795076] Mon, 17 September 2018 06:55 Go to previous messageGo to next message
Member
Hi Yoann,
The contribution to fix the bug was merged this friday, It will be available in the next release of papyrus i.e. in December 2018.
Nicolas
Re: Bug in Sequence Diagram [message #1795166 is a reply to message #1795149] Mon, 17 September 2018 15:21 Go to previous message
Hi Nicolas,
Works for me too. Thank you.
Yoann.
Previous Topic:Cannot create connectors
Next Topic:Error installing Papyrus on Ubuntu
Current Time: Fri Oct 23 01:19:11 GMT 2020
Powered by FUDForum. Page generated in 0.02329 seconds
