Home » Eclipse Projects » Eclipse Titan » Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder(Unified Diagnostic Services RAW encoder / decoder)
Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder [message #1794920] Tue, 11 September 2018 06:43 Go to next message
Michael Josenhans is currently offline Michael JosenhansFriend
Member
I have created a subset of the Unified Diagnostic Services (UDS) ISO 14229.
type enumerated SuppressPosRspMsgIndicationBitType {
  doNotsuppresssPos (0),
  suppresssPos      (1)
with {variant "FIELDLENGTH(1)"}
type OCT1 DiagnosticSessionType
type record DefaultSessionRequest {
  DiagnosticSessionType     diagnosticSessionType ('01'O)
} with { variant "" };
type record ProgrammingSessionRequest {
  DiagnosticSessionType     diagnosticSessionType ('02'O)
type record ExtendedDiagnosticSessionRequest {
  DiagnosticSessionType     diagnosticSessionType ('03'O)
type record SafetySystemDiagnosticSessionRequest {
  DiagnosticSessionType     diagnosticSessionType ('04'O)
type union DiagnosticSessionRequestType
  DefaultSessionRequest                  defaultSession,
  ProgrammingSessionRequest              programmingSession,
  ExtendedDiagnosticSessionRequest       extendedDiagnosticSession,
  SafetySystemDiagnosticSessionRequest   safetySystemDiagnosticSession
with {variant "TAG	(
  defaultSession,                diagnosticSessionType = '01'O;
  programmingSession,            diagnosticSessionType = '02'O;
  extendedDiagnosticSession,     diagnosticSessionType = '03'O;
  safetySystemDiagnosticSession, diagnosticSessionType = '04'O)";
  variant "FIELDLENGTH(7)"
type record DiagnosticSessionControlRequestSID
  SID                                   sid ('10'O),
  SuppressPosRspMsgIndicationBitType    suppressPosRspMsgIndicationBit,
  DiagnosticSessionRequestType          diagnosticSessionType
} with { variant "FIELDORDER(msb)" };
type record TesterPresentRequestSID
  SID                                   sid  ('3E'O),
  BIT7                                  zero ('0000000'B)
The SuppressPosRspMsgIndicationBitType (1 bit) forms together with the following 7 bit type when encoding / decoding a Byte. That's why I have defined DiagnosticSessionRequestType as FIELDLENGTH(7).
When encoding / decoding DiagnosticSessionRequestType encodes to a 3 byte value instead of the expected 2 byte value '1083'O and decodes even to a differnt than the encoded value (after decoding the suppressPosRspMsgIndicationBit changes from suppresssPos to doNotsuppresssPos):
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Encoding @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := suppresssPos (1), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Stream after encoding: '100600'O
MTC@Donald: '100600'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Stream before decoding: '100600'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Decoded @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := doNotsuppresssPos (0), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
MTC@Donald: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := doNotsuppresssPos (0), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
TesterPresentRequestSID with the paramter suppresssPos (1) encodes to '3E80'O, what it should:
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Encoding @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Stream after encoding: '3E80'O
MTC@Donald: '3E80'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Stream before decoding: '3E80'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Decoded @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
MTC@Donald: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
Is it necessary to change the DiagnosticSessionRequestType to:
type BIT7 DiagnosticSessionType
  DiagnosticSessionType     diagnosticSessionType ('0000001'B)
  DiagnosticSessionType     diagnosticSessionType ('0000010'B)
  DiagnosticSessionType     diagnosticSessionType ('0000011'B)
  DiagnosticSessionType     diagnosticSessionType ('0000100'B)
  defaultSession,                diagnosticSessionType = '0000001'B;
  programmingSession,            diagnosticSessionType = '0000010'B;
  extendedDiagnosticSession,     diagnosticSessionType = '0000011'B;
  safetySystemDiagnosticSession, diagnosticSessionType = '0000100'B)";
Re: Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder [message #1794933 is a reply to message #1794920] Tue, 11 September 2018 09:55 Go to previous messageGo to next message
Botond Baranyi is currently offline Botond BaranyiFriend
Member
yes, it's necessary to change the type of DiagnosticSessionType to BIT7. You could also create separate DiagnosticSessionType types for requests and responses, if the response types still need an OCT1 field.
Even with this change the enumerated field is still encoded incorrectly. I'm currently investigating this issue.
Botond Baranyi
Re: Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder [message #1794986 is a reply to message #1794920] Wed, 12 September 2018 08:59 Go to previous message
Member
for the second issue: the attribute 'FIELDORDER(msb)' does not extend to lower level records/sets. Because of this the 1 bit for the enumerated type is encoded as the MSB in the octet, and the 7 bits in the ...SessionRequest records are encoded with LSB first (thus overwriting the enum's bit).
This is an undocumented limitation of the attribute FIELDORDER.
To fix this you'd need to add the attribute 'FIELDORDER(msb)' to the ...SessionRequest records.
Like this:
  RequestDiagnosticSessionType     diagnosticSessionType ('0000001'B)
  RequestDiagnosticSessionType     diagnosticSessionType ('0000010'B)
  RequestDiagnosticSessionType     diagnosticSessionType ('0000011'B)
  RequestDiagnosticSessionType     diagnosticSessionType ('0000100'B)
Botond Baranyi
Previous Topic:Titan intermediate release 6.4.1
Next Topic:Limitation on TTCN support.
Current Time: Mon Jan 25 02:23:43 GMT 2021
Powered by FUDForum. Page generated in 0.02261 seconds
