Home » Eclipse Projects » e(fx)clipse » javafx-swt.jar not in the classpath when using java10
javafx-swt.jar not in the classpath when using java10 [message #1794899] Mon, 10 September 2018 11:52 Go to next message
I have an eclipse plugin that uses FXCanvas and javafx-swt.
This works fine with java 8 (pointing to lib/javafxswt.jar) and with java 9 (pointing to javafx-swt.jar)
but it doesn't work with java 10. (even if javafx-swt.jar is present in /usr/lib/jvm/java-10-oracle/lib )
Is there an update of Efxclipse that fixes that ? (I use efxclipse 3.3.0.20180528 bundled with photon)
This is quite annoying because, unfortunately there is no way to download java 9 anymore, only java 10.
next question, will java 11 (which is planned for the end of the month) be also supported ?
Didier
Re: javafx-swt.jar not in the classpath when using java10 [message #1794924 is a reply to message #1794899] Tue, 11 September 2018 03:55 Go to previous message
On OpenJFX-11 is supported (see https://tomsondev.bestsolution.at/2018/08/04/supporting-openjfx-11-from-jdk11-onwards-in-efxclipse/) but you need to ship OpenJFX yourself, I'm still trying to figure out how to provide rebundled OSGi-Artifacts.
On Java10 - please give the latest build a spin to see if things work there. As Java10 is out-dated once Java11 is released even if it does not work I'm not sure it is worth fixing the Java10 problem.
Previous Topic:Cannot use "Generate Javafx getter and setters"
Next Topic:Support for Java11 / Open JFX 11 is on the way
Current Time: Fri Mar 28 10:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.03605 seconds
