Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse 3.7 RCP App -> e4 RCP
Eclipse 3.7 RCP App -> e4 RCP [message #1794743] Wed, 05 September 2018 17:15
Howdy,
I'm endeavoring to update the target platform for an Eclipse RCP app based upon Eclipse 3.7.
I've added all the Eclipse deps to Photon version and am getting the following startup error:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-09-05 15:58:31.103
!MESSAGE Unable to load resource platform:/plugin/<deleted>.ui/Application.e4xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.FileNotFoundException: /Application.e4xmi
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.getResource(ResourceHandler.java:282)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:258)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:177)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:378)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:253)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:149)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Caused by: java.io.FileNotFoundException: /Application.e4xmi
at org.eclipse.osgi.storage.url.bundleentry.Handler.findBundleEntry(Handler.java:51)
at org.eclipse.osgi.storage.url.BundleResourceHandler.openConnection(BundleResourceHandler.java:169)
at java.net.URL.openConnection(URL.java:979)
at org.eclipse.core.internal.boot.PlatformURLConnection.connect(PlatformURLConnection.java:112)
at org.eclipse.core.internal.boot.PlatformURLConnection.connect(PlatformURLConnection.java:93)
at org.eclipse.core.internal.boot.PlatformURLConnection.getInputStream(PlatformURLConnection.java:228)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:207)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1314)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 20 more
!ENTRY org.eclipse.osgi 4 0 2018-09-05 15:58:31.161
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:178)
An error has occurred. See the log file
Of course there is no Application.e4xmi file, as it was an Eclipse 3.7 RCP app. But...I've been away from RCP for a while...I had thought that there was a compatibility mode for RCP 3.x plugins...or perhaps that has gone away? Is there any way to just use the old product config and app plugin.xml and run on Eclipse e4 now?...e.g. with some legacy .e3xml file, or perhapsthe old rcp stuff in plugin.xml be converted to Application.e4xmi and then be run?
Thanksinadvance for any information or pointers,
Scott
Previous Topic:How to add keydown/up event listener on eclipse rcp editor view?
Next Topic:Eclipse Photon (4.8.0) RCP application plug-ins loading issue
Current Time: Thu May 15 10:08:35 EDT 2025
Powered by FUDForum. Page generated in 0.03447 seconds
