Arrang All Problem using Sirius & ELK [message #1794531] |
Sat, 01 September 2018 01:45 |
Nicholas Kong Messages: 59 Registered: July 2016 Location: China |
Member |
To Whom It May Concern,
When I use Sirius 6.0, which has integrated ELK function.
I use the family example, and give the diagram layout function is 'ELK Layered', without any specific global option.
I found a problem, if I click the 'Arrange All' button multi-time, the diagram element size will be bigger in every time.
You can see after several 'Arrange All', Clara is bigger than 1st time.
But, you can see the Paul, who is in the top right corner, does not change the size.
This problem not only shown Sirius(6.0) & ELK(0.3), but also shown Sirius(4.1.3) & ELK(0.2.2), so I think this problem may a defect of Sirius & ELK integration.
I attach the metamodel and model, and create a defect in Sirius Bugzilla.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=538498
[Updated on: Sat, 01 September 2018 06:21] Report message to a moderator
FUDForum. Page generated in 0.03016 seconds
