Home » Eclipse Projects » EGit / JGit » Create bare Jgit repo with public ssh key auth(Need to write test case which can clone repo with ssh private key)
Create bare Jgit repo with public ssh key auth [message #1794482] Fri, 31 August 2018 07:21 Go to next message
Shashank Singh is currently offline Shashank SinghFriend
To write test case which can clone a repo with ssh private key, we need to create a bare Git repo which we can create with ssh public key user.
The code I'm using to create bare repo:
File root = new File("target/junk/repo");
File bareRoot = new File("target/junk/bare-repo.git");
Git bare = createBareRepository(bareRoot);
Git.init().setDirectory(root).setBare(true).call();
And this is how I'll like to clone the repo in my unit test
Git.cloneRepository()
        .setURI(url)
        .setRemote(remote)
        .setDirectory(path)
        .setTransportConfigCallback(new TransportConfigCallback() {
        public void configure( Transport transport ) {
          SshTransport sshTransport = ( SshTransport )transport;
          sshTransport.setSshSessionFactory( sshSessionFactory );
      }).call();
Re: Create bare Jgit repo with public ssh key auth [message #1794505 is a reply to message #1794482] Fri, 31 August 2018 14:31 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
I am not sure what is your question ?
If you want to create a repository remotely over ssh git protocol, this is not possible since the git protocol
(also git over ssh or git over https) doesn't support that.
You can create a repository locally in the way you described above. In order to serve it via ssh you need
a ssh daemon implementation. JGit doesn't have any. You may have a look at how Gerrit implements that [1]
using Apache Mina SSHD.
[1] https://gerrit.googlesource.com/gerrit/+/master/java/com/google/gerrit/sshd/SshDaemon.java
Previous Topic:Wanna use 'org.eclipse.egit.github.core' in a project
Next Topic:Does EGit 5.x support the Git protocol version 2?
Current Time: Tue Apr 16 09:25:37 GMT 2024
Powered by FUDForum. Page generated in 0.87841 seconds
