Home » Modeling » TMF (Xtext) » Usage of IContextualOutputConfigurationProvider(2)
Usage of IContextualOutputConfigurationProvider(2) [message #1794472] Fri, 31 August 2018 02:18 Go to next message
in my DSL the outputdirectory depends on the resource. The IOutputConfigurationProvider does not consider any context (like a resource).
I stumbled upon IContextualOutputConfigurationProvider(2) and bound a class which implements these interfaces, but unfortunately IContextualOutputConfigurationProvider.getOutputConfigurations(Resource) seems not to be called.
How can I achieve that the methods of IContextualOutputConfigurationProvider(2) are called?
Kind regrads
Oliver
Re: Usage of IContextualOutputConfigurationProvider(2) [message #1794473 is a reply to message #1794472] Fri, 31 August 2018 02:24 Go to previous messageGo to next message
what is your exact usecase. in eclipse EclipseOutputConfigurationProvider is used
Re: Usage of IContextualOutputConfigurationProvider(2) [message #1794474 is a reply to message #1794473] Fri, 31 August 2018 02:38 Go to previous messageGo to next message
There are a couple of properties which affect how the generator works. In order to use the same properties in Eclipse and standalone I do not want to rely on Eclipse APIs (Preferences) and just would like to use a simple properties file.
This properties file is located next to my model resources. One property is the outputdirectory of a certain outputconfigurationame, something like:
outputdirectory.GEN_JAVA=target/generated-sources/main
But there are also properties which do not apply to output configuration. Think about a feature toggle to enable/disable the generation of interfaces.
I need this because my generator is a configurable platform which is used for multiple projects which have different requirements. These feature toggles are a way to configure the code generation without the need create plugins which bind other implementations.
To cut a long story short, I would like to configure the DSL/generator in my model project and the configuration should apply to Eclipse and standalone (Maven).
Re: Usage of IContextualOutputConfigurationProvider(2) [message #1794480 is a reply to message #1794474] Fri, 31 August 2018 03:13 Go to previous messageGo to next message
you should debug after EclipseOutputConfigurationProvider in eclipse?
or is your "no working" for the standalone case the question is which infrastructure do you use.
i am not sure that the maven one uses that at all
Re: Usage of IContextualOutputConfigurationProvider(2) [message #1794492 is a reply to message #1794480] Fri, 31 August 2018 05:58 Go to previous message
The only solution I found is to override org.eclipse.xtext.builder.BuilderParticipant.getOutputConfigurations(IBuildContext);
	protected Map<String, OutputConfiguration> getOutputConfigurations(IBuildContext context) {
		Set<OutputConfiguration> configurations = getOutputConfigurationProvider().getOutputConfigurations(context.getResourceSet());
		return uniqueIndex(configurations, new Function<OutputConfiguration, String>() {
			public String apply(OutputConfiguration from) {
				return from.getName();
I found a similar thread here: https://www.eclipse.org/forums/index.php?t=msg&th=1083997&goto=1752776&
Previous Topic:Library issue with New Project Wizard in 2.14
Next Topic:Using WS as delimiter in part of grammar
Current Time: Tue Jul 08 21:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.05689 seconds
