Home » Eclipse Projects » Advanced Scripting Environment (EASE) » How to debug Python script launched from Java
How to debug Python script launched from Java [message #1794290] Tue, 28 August 2018 13:44 Go to next message
Lutz Wrage is currently offline Lutz WrageFriend
I have the following scenario: In an Eclipse application I have a plugin that runs a python script located in the workspace. I got this to work with the py4j engine. Now I'd like to be able to debug the script execution.
Does anyone have advice or example code that shows how to do this? Could also be for Javascript, I assume the code would be somewhat similar.
Re: How to debug Python script launched from Java [message #1794393 is a reply to message #1794290] Thu, 30 August 2018 06:51 Go to previous message
Christian Pontesegger is currently offline Christian PonteseggerFriend
Do you want to launch the debug process programmatically?
If you already have a working launch/debug configuration stored in your workspace you may use the Launch module to run it.
If not, check out the LaunchDelegate from EASE:
http://git.eclipse.org/c/ease/org.eclipse.ease.core.git/tree/plugins/org.eclipse.ease.ui/src/org/eclipse/ease/ui/launching/EaseLaunchDelegate.java
roughly around line 160.
HTH
Christian
Previous Topic:Release Schedule?
Next Topic:Dependencies required for EASE on eclipse 4.10/4.11
Current Time: Sun Dec 10 21:37:38 GMT 2023
Powered by FUDForum. Page generated in 0.02019 seconds
