Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » On linux screen messes up when doing horizontal scrolling(eclipse photon is "unsuable" on linux platform)
On linux screen messes up when doing horizontal scrolling [message #1794053] Thu, 23 August 2018 03:26 Go to next message
Prem Mehrotra is currently offline Prem MehrotraFriend
I have June 2018 Eclipse Photon a redhat linux 7. I only have gtk 2 installed; had to remove gtk 3 because eclipse could not be started. Anyway, with gtk2, when I open a Java 9 project, in the text editor If I do horizontal scrolling, it messes up screen, it draws a few vertical scrollbars (in addition to a vertical scrollbar) at the end. I am using Exceed Hummingbird on my PC as a X-Server.
I have been using Eclipse Kepler for years on redhat linux without any problems, but photon has scrolling issues, so it is unusable.
How can I overcome this problem? I searched on google while problem has been reported, no solutions (which work) are provided.
Appreciate your response. If I cannot resolve the problem, I will have to run Eclipse from my PC on Windows.
Re: On linux screen messes up when doing horizontal scrolling [message #1794736 is a reply to message #1794053] Wed, 05 September 2018 17:54 Go to previous message
jack logan is currently offline jack loganFriend
Try removing gtk 3 and it's successor gtk 4 after that install those in the Javascript am sure you will get a clear solution of your problem. I myself faced this same problem but this helped me. Thanks and Regards, panda helper emu4ios gbwhatsapphttps://getgbwhatsapp.biz/https://emu4ios.biz/https://pandahelper.me/
[Updated on: Fri, 07 September 2018 16:30]
Report message to a moderator
Previous Topic:Regression: Java 10 is not supported in Proton project facets
Next Topic:Warnings: Discouraged in HTML5 documents?
Current Time: Mon Oct 26 01:49:32 GMT 2020
Powered by FUDForum. Page generated in 0.02206 seconds
