Home » Eclipse Projects » WindowBuilder » Design view won't work(WindowBuilder design view won't seem to work)
Design view won't work [message #1793613] Sat, 11 August 2018 17:29 Go to next message
Ivan Colon is currently offline Ivan ColonFriend
So recently I am trying to create a new project using WindowBuilder and when I click on design view it says Incompatible Java Version. I proceeded to update both the JDK and JRE and I still get the same problem. I've included a screenshot with what it says. Any help will be appreciated. Thanks.
  • Attachment: Capture.PNG
    (Size: 91.37KB, Downloaded 271 times)
Re: Design view won't work [message #1793678 is a reply to message #1793613] Tue, 14 August 2018 02:42 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
Did you try the suggestion shown in the error message shown in your screenshot?
Eclipse needs to run in the same or higher version of Java used for the project.
Re: Design view won't work [message #1795037 is a reply to message #1793678] Thu, 13 September 2018 09:30 Go to previous message
Wim Jongman is currently offline Wim JongmanFriend
Update to 1.9.1
https://www.eclipse.org/windowbuilder/download.php
Wim
Previous Topic:WindowBuilder Updates
Next Topic:where can i download Source code about WindowBuilder?
Current Time: Tue Apr 16 23:45:11 GMT 2024
Powered by FUDForum. Page generated in 6.67214 seconds
