Home » Eclipse Projects » Remote Application Platform (RAP) » Cursor on ToolItem
Cursor on ToolItem [message #1793589] Fri, 10 August 2018 16:55 Go to next message
Chris Merg is currently offline Chris MergFriend
Hello everyone,
Was wondering if it's possible to change the cursor when hovering over ToolItems inside a ToolBar. I can only setCursor of ToolBar but not of the ToolItem I've created. This would be very useful for Push-Toolitems in order to signalize a possible event to the user.
Chris
Re: Cursor on ToolItem [message #1793964 is a reply to message #1793589] Tue, 21 August 2018 09:07 Go to previous message
Sebastian Habenicht is currently offline Sebastian HabenichtFriend
Member
I think it is not possible to set the cursor on a ToolItem since ToolItem extends Item, not Control.
What you can do is to use a Composite instead of a ToolBar and to use ActionContributionItem. This class creates a Button when fill(Composite parent) is used. You can access the button via getWidget and set a cursor to it. Alternatively, define the cursor via css for Buttons.
Sebastian
Previous Topic:ExpandableComposite Twistie style not rendering
Next Topic:Select a custom theme for the application on startup
Current Time: Thu Feb 20 15:09:28 GMT 2020
Powered by FUDForum. Page generated in 0.01904 seconds
