| NULL pointer when opening sirius diagram firstly [message #1793479] |
Wed, 08 August 2018 23:43  |
I have integrated ELK 0.4.1 into eclipse(neon), when I open a diagram in sirius editor, there an NullPointerException occurs as follows:
at org.eclipse.elk.alg.layered.graph.transform.ElkGraphImporter.transformExternalPort(ElkGraphImporter.java:631)
at org.eclipse.elk.alg.layered.graph.transform.ElkGraphImporter.importGraph(ElkGraphImporter.java:97)
at org.eclipse.elk.alg.layered.graph.transform.ElkGraphTransformer.importGraph(ElkGraphTransformer.java:34)
at org.eclipse.elk.alg.layered.graph.transform.ElkGraphTransformer.importGraph(ElkGraphTransformer.java:1)
at org.eclipse.elk.alg.layered.LayeredLayoutProvider.layout(LayeredLayoutProvider.java:53)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.executeAlgorithm(RecursiveGraphLayoutEngine.java:222)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layoutRecursively(RecursiveGraphLayoutEngine.java:197)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:76)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:718)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:650)
at org.eclipse.elk.core.service.DiagramLayoutEngine$1.execute(DiagramLayoutEngine.java:400)
at org.eclipse.elk.core.service.util.MonitoredOperation$1.run(MonitoredOperation.java:236)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
[Updated on: Wed, 08 August 2018 23:45] by Moderator
| Re: NULL pointer when opening sirius diagram firstly [message #1793489 is a reply to message #1793485] |
Thu, 09 August 2018 02:41   |
Ok , I will publish this issue to Github.
At the same time, have another question, after my installation, I found the three Xtext plugins(graph.text,graph.text.ui,graph.text.ide ) of graph can't be installed successfuly. After my research, I think the plugins are just used to create models for running example in other plugins, so I have no need to install it into my eclipse,.
Am I right about this ?
Hope for your reply!
| Re: NULL pointer when opening sirius diagram firstly [message #1793502 is a reply to message #1793489] |
Thu, 09 August 2018 05:13   |
zhang ph wrote on Thu, 09 August 2018 06:41
That is correct. :)
| Re: NULL pointer when opening sirius diagram firstly [message #1793683 is a reply to message #1793502] |
Tue, 14 August 2018 03:24   |
Thanks !!!
Then I built elk 0.4.0 with maven, but when building elk.core, there errors occur like below:
[INFO] Building ELK Core Components 0.4.0
[INFO] ------------------------------------------------------------------------
[INFO]
[INFO] --- tycho-packaging-plugin:1.0.0:build-qualifier (default-build-qualifier) @ org.eclipse.elk.core ---
[INFO] The project's OSGi version is 0.4.0
[INFO]
[INFO] --- tycho-packaging-plugin:1.0.0:validate-id (default-validate-id) @ org.eclipse.elk.core ---
[INFO]
[INFO] --- tycho-packaging-plugin:1.0.0:validate-version (default-validate-version) @ org.eclipse.elk.core ---
[INFO]
[INFO] --- xtext-maven-plugin:2.10.0:generate (default) @ org.eclipse.elk.core ---
[WARNING] Could not transfer metadata org.eclipse.elk:org.eclipse.elk.graph/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer com.google.guava:guava/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata com.google.guava:guava/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.elk:org.eclipse.elk.core.meta/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtext:org.eclipse.xtext/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtext:org.eclipse.xtext.util/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.util/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.ecore/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.ecore/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.common/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.common/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtend:org.eclipse.xtend.lib/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtend:org.eclipse.xtend.lib/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.ecore.xmi/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.ecore.xmi/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.antlr:antlr-runtime/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.antlr:antlr-runtime/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtext:org.eclipse.xtext.xbase.lib/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.xbase.lib/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtext:org.eclipse.xtext.common.types/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.common.types/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.codegen/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.mwe2.runtime/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.mwe2.runtime/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.builder.standalone/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.xtext:org.eclipse.xtext.xbase/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.xbase/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.ecore/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.generator/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20130930-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20130930-SNAPSHOT/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20130930-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20130930-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20130930-20131101.184147-1.pom
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20130930-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20130930-20131101.184147-1.pom
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20130930-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20130930-20131101.184147-1.pom (2 KB at 0.3 KB/sec)
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/maven-metadata.xml
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/maven-metadata.xml
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/maven-metadata.xml (827 B at 0.2 KB/sec)
[WARNING] Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140127-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140127-SNAPSHOT/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140127-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140127-20140308.162034-2.pom
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140127-20140308.162034-2.pom
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140127-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140127-20140308.162034-2.pom (2 KB at 0.2 KB/sec)
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/maven-metadata.xml
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/maven-metadata.xml
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/maven-metadata.xml (827 B at 1.1 KB/sec)
[WARNING] Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140519-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
[WARNING] Failure to transfer org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140519-SNAPSHOT/maven-metadata.xml from ${elkMeta.repositoryUrl} was cached in the local repository, resolution will not be reattempted until the update interval of eclipse-elk-meta has elapsed or updates are forced. Original error: Could not transfer metadata org.eclipse.emf:org.eclipse.emf.codegen.ecore:2.10.0-v20140519-SNAPSHOT/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140519-20140615.074844-1.pom
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140519-20140615.074844-1.pom
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-SNAPSHOT/org.eclipse.emf.codegen.ecore-2.10.0-v20140519-20140615.074844-1.pom (2 KB at 1.5 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-0339/org.eclipse.emf.codegen.ecore-2.10.0-v20140519-0339.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.0-v20140519-0339/org.eclipse.emf.codegen.ecore-2.10.0-v20140519-0339.pom (2 KB at 0.6 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.1/org.eclipse.emf.codegen.ecore-2.10.1.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.1/org.eclipse.emf.codegen.ecore-2.10.1.pom (2 KB at 0.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.1-v20140901-1055/org.eclipse.emf.codegen.ecore-2.10.1-v20140901-1055.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.1-v20140901-1055/org.eclipse.emf.codegen.ecore-2.10.1-v20140901-1055.pom (2 KB at 1.4 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.2-v20150123-0452/org.eclipse.emf.codegen.ecore-2.10.2-v20150123-0452.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.10.2-v20150123-0452/org.eclipse.emf.codegen.ecore-2.10.2-v20150123-0452.pom (2 KB at 1.5 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0/org.eclipse.emf.codegen.ecore-2.11.0.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0/org.eclipse.emf.codegen.ecore-2.11.0.pom (2 KB at 1.4 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0-v20150123-0357/org.eclipse.emf.codegen.ecore-2.11.0-v20150123-0357.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0-v20150123-0357/org.eclipse.emf.codegen.ecore-2.11.0-v20150123-0357.pom (2 KB at 0.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0-v20150806-0404/org.eclipse.emf.codegen.ecore-2.11.0-v20150806-0404.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0-v20150806-0404/org.eclipse.emf.codegen.ecore-2.11.0-v20150806-0404.pom (2 KB at 1.5 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.12.0/org.eclipse.emf.codegen.ecore-2.12.0.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.12.0/org.eclipse.emf.codegen.ecore-2.12.0.pom (2 KB at 1.6 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/maven-metadata.xml
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/xtext/xtext-antlr-generator/maven-metadata.xml
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/xtext/xtext-antlr-generator/maven-metadata.xml
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/maven-metadata.xml (376 B at 0.5 KB/sec)
[WARNING] Could not transfer metadata org.eclipse.xtext:xtext-antlr-generator/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/2.1.1/xtext-antlr-generator-2.1.1.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/2.1.1/xtext-antlr-generator-2.1.1.pom (6 KB at 0.9 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/xtext/antlr-generator/3.2.1/antlr-generator-3.2.1.pom
Downloaded: http://repo1.maven.org/maven2/org/xtext/antlr-generator/3.2.1/antlr-generator-3.2.1.pom (5 KB at 5.3 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/antlr/stringtemplate/3.2/stringtemplate-3.2.pom
Downloaded: http://repo1.maven.org/maven2/org/antlr/stringtemplate/3.2/stringtemplate-3.2.pom (2 KB at 3.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/antlr/antlr/2.7.7/antlr-2.7.7.pom
Downloaded: http://repo1.maven.org/maven2/antlr/antlr/2.7.7/antlr-2.7.7.pom (632 B at 0.9 KB/sec)
Downloading: https://repo.eclipse.org/content/repositories/cbi-releases/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/maven-metadata.xml
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/maven-metadata.xml
Downloading: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/maven-metadata.xml
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/maven-metadata.xml (2 KB at 1.4 KB/sec)
Downloaded: https://oss.sonatype.org/content/repositories/snapshots/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/maven-metadata.xml (536 B at 0.4 KB/sec)
[WARNING] Could not transfer metadata org.eclipse.xtext:org.eclipse.xtext.xtext.generator/maven-metadata.xml from/to eclipse-elk-meta (${elkMeta.repositoryUrl}): Cannot access ${elkMeta.repositoryUrl} with type default using the available connector factories: BasicRepositoryConnectorFactory
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/2.10.0/org.eclipse.xtext.xtext.generator-2.10.0.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/2.10.0/org.eclipse.xtext.xtext.generator-2.10.0.pom (3 KB at 3.0 KB/sec)
Downloading: http://repo1.maven.org/maven2/com/ibm/icu/icu4j/52.1/icu4j-52.1.pom
Downloaded: http://repo1.maven.org/maven2/com/ibm/icu/icu4j/52.1/icu4j-52.1.pom (5 KB at 4.9 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.utils/1.3.13/org.eclipse.emf.mwe.utils-1.3.13.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.utils/1.3.13/org.eclipse.emf.mwe.utils-1.3.13.pom (788 B at 1.6 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.core/1.3.13/org.eclipse.emf.mwe.core-1.3.13.pom
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.core/1.3.13/org.eclipse.emf.mwe.core-1.3.13.pom (2 KB at 1.5 KB/sec)
Downloading: http://repo1.maven.org/maven2/commons-cli/commons-cli/1.2/commons-cli-1.2.pom
Downloaded: http://repo1.maven.org/maven2/commons-cli/commons-cli/1.2/commons-cli-1.2.pom (8 KB at 5.3 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/commons/commons-parent/11/commons-parent-11.pom
Downloaded: http://repo1.maven.org/maven2/org/apache/commons/commons-parent/11/commons-parent-11.pom (25 KB at 3.7 KB/sec)
Downloading: http://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.pom
Downloaded: http://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.pom (18 KB at 14.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/apache/commons/commons-parent/28/commons-parent-28.pom
Downloaded: http://repo1.maven.org/maven2/org/apache/commons/commons-parent/28/commons-parent-28.pom (49 KB at 56.6 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.builder.standalone/2.10.0/org.eclipse.xtext.builder.standalone-2.10.0.jar
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.ecore/2.10.0/org.eclipse.xtext.ecore-2.10.0.jar
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.12.0/org.eclipse.emf.codegen.ecore-2.12.0.jar
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.generator/2.10.0/org.eclipse.xtext.generator-2.10.0.jar
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/2.1.1/xtext-antlr-generator-2.1.1.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/xtext-antlr-generator/2.1.1/xtext-antlr-generator-2.1.1.jar (8 KB at 2.1 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/xtext/antlr-generator/3.2.1/antlr-generator-3.2.1.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.generator/2.10.0/org.eclipse.xtext.generator-2.10.0.jar (877 KB at 251.6 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/2.10.0/org.eclipse.xtext.xtext.generator-2.10.0.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.builder.standalone/2.10.0/org.eclipse.xtext.builder.standalone-2.10.0.jar (65 KB at 18.2 KB/sec)
Downloading: http://repo1.maven.org/maven2/com/ibm/icu/icu4j/52.1/icu4j-52.1.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.12.0/org.eclipse.emf.codegen.ecore-2.12.0.jar (1056 KB at 297.8 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.utils/1.3.13/org.eclipse.emf.mwe.utils-1.3.13.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.ecore/2.10.0/org.eclipse.xtext.ecore-2.10.0.jar (18 KB at 4.5 KB/sec)
Downloading: http://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar
Downloaded: http://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar (61 KB at 12.9 KB/sec)
Downloading: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.core/1.3.13/org.eclipse.emf.mwe.core-1.3.13.jar
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.utils/1.3.13/org.eclipse.emf.mwe.utils-1.3.13.jar (30 KB at 5.9 KB/sec)
Downloading: http://repo1.maven.org/maven2/commons-cli/commons-cli/1.2/commons-cli-1.2.jar
Downloaded: http://repo1.maven.org/maven2/commons-cli/commons-cli/1.2/commons-cli-1.2.jar (41 KB at 5.3 KB/sec)
Downloaded: http://repo1.maven.org/maven2/org/eclipse/emf/org.eclipse.emf.mwe.core/1.3.13/org.eclipse.emf.mwe.core-1.3.13.jar (170 KB at 16.2 KB/sec)
Downloaded: http://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.xtext.generator/2.10.0/org.eclipse.xtext.xtext.generator-2.10.0.jar (1095 KB at 45.9 KB/sec)
Downloaded: http://repo1.maven.org/maven2/org/xtext/antlr-generator/3.2.1/antlr-generator-3.2.1.jar (1450 KB at 49.5 KB/sec)
6524/10222 KB
Downloaded: http://repo1.maven.org/maven2/com/ibm/icu/icu4j/52.1/icu4j-52.1.jar (10222 KB at 35.6 KB/sec)
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.6
[INFO] Compiler target level: 1.6
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[INFO] Generating stubs into /home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/target/xtext-temp/stubs
[INFO] Compiling stubs located in /home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/target/xtext-temp/stubs
[INFO] Installing type provider for stubs.
[INFO] Validate and generate.
[INFO] Starting validation for input: 'Labels.melk'
[ERROR] ERROR:ILabelManager cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/labels/Labels.melk line : 22 column : 35)
[INFO] Starting validation for input: 'Core.melk'
[ERROR] ERROR:LayoutAlgorithmData cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 165 column : 40)
[ERROR] ERROR:Alignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 171 column : 28)
[ERROR] ERROR:KVectorChain cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 189 column : 33)
[ERROR] ERROR:Direction cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 207 column : 19)
[ERROR] ERROR:EdgeRouting cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 216 column : 21)
[ERROR] ERROR:HierarchyHandling cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 237 column : 36)
[ERROR] ERROR:ElkPadding cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 250 column : 26)
[ERROR] ERROR:PortConstraints cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 472 column : 25)
[ERROR] ERROR:KVector cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 480 column : 27)
[ERROR] ERROR:KVectorChain cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 548 column : 31)
[ERROR] ERROR:ILabelManager cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 620 column : 35)
[ERROR] ERROR:ElkMargin cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 626 column : 30)
[ERROR] ERROR:PackingMode cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 132 column : 25)
[ERROR] ERROR:IndividualSpacings cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 364 column : 38)
[ERROR] ERROR:ElkMargin cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 373 column : 36)
[ERROR] ERROR:ElkPadding cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 409 column : 27)
[ERROR] ERROR:NodeLabelPlacement cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 417 column : 28)
[ERROR] ERROR:PortAlignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 431 column : 19)
[ERROR] ERROR:PortAlignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 439 column : 25)
[ERROR] ERROR:PortAlignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 447 column : 25)
[ERROR] ERROR:PortAlignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 455 column : 24)
[ERROR] ERROR:PortAlignment cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 463 column : 24)
[ERROR] ERROR:SizeConstraint cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 517 column : 30)
[ERROR] ERROR:SizeOptions cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 527 column : 26)
[ERROR] ERROR:KVector cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 537 column : 27)
[ERROR] ERROR:EdgeLabelPlacement cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 574 column : 20)
[ERROR] ERROR:KVector cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 654 column : 30)
[ERROR] ERROR:PortSide cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 672 column : 28)
[ERROR] ERROR:PortLabelPlacement cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 701 column : 20)
[ERROR] ERROR:EdgeType cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 777 column : 28)
[ERROR] ERROR:The method or field Alignment is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 176 column : 12)
[ERROR] ERROR:The method or field ExclusiveBounds is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 184 column : 18)
[ERROR] ERROR:The method or field Direction is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 211 column : 12)
[ERROR] ERROR:The method or field EdgeRouting is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 223 column : 12)
[ERROR] ERROR:The method or field HierarchyHandling is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 245 column : 12)
[ERROR] ERROR:ElkPadding cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 256 column : 19)
[ERROR] ERROR:The method or field PortConstraints is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 475 column : 12)
[ERROR] ERROR:KVectorChain cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 557 column : 16)
[ERROR] ERROR:ElkMargin cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 633 column : 16)
[ERROR] ERROR:The method or field ExclusiveBounds is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 731 column : 18)
[ERROR] ERROR:The method or field BoxLayoutProvider is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 139 column : 19)
[ERROR] ERROR:ElkMargin cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 380 column : 17)
[ERROR] ERROR:ElkPadding cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 412 column : 17)
[ERROR] ERROR:The method or field NodeLabelPlacement is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 422 column : 13)
[ERROR] ERROR:The method or field PortAlignment is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 434 column : 13)
[ERROR] ERROR:The method or field SizeConstraint is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 523 column : 28)
[ERROR] ERROR:The method or field SizeOptions is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 533 column : 24)
[ERROR] ERROR:KVector cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 540 column : 17)
[ERROR] ERROR:The method or field EdgeLabelPlacement is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 577 column : 13)
[ERROR] ERROR:The method or field PortSide is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 678 column : 13)
[ERROR] ERROR:The method or field PortLabelPlacement is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 704 column : 13)
[ERROR] ERROR:The method or field EdgeType is undefined (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 782 column : 13)
[ERROR] ERROR:ElkPadding cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 104 column : 25)
[ERROR] ERROR:ElkPadding cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 116 column : 25)
[ERROR] ERROR:ElkPadding cannot be resolved. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 151 column : 25)
[ERROR] ERROR:org.eclipse.elk.core.data.LayoutAlgorithmData cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 14 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.labels.ILabelManager cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 15 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.math.ElkMargin cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 16 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.math.ElkPadding cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 17 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.math.KVector cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 18 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.math.KVectorChain cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 19 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.BoxLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 20 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.BoxLayoutProvider.PackingMode cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 21 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.ExclusiveBounds cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 22 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.FixedLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 23 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.IndividualSpacings cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 24 column : 8)
[ERROR] ERROR:org.eclipse.elk.core.util.RandomLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 25 column : 8)
[ERROR] ERROR:FixedLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 98 column : 17)
[ERROR] ERROR:BoxLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 111 column : 15)
[ERROR] ERROR:RandomLayoutProvider cannot be resolved to a type. (file:/home/ph.zhang/SourceCode/elk-releases-0.4.0/plugins/org.eclipse.elk.core/src/org/eclipse/elk/core/Core.melk line : 144 column : 18)
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse Layout Kernel .............................. SUCCESS [ 0.003 s]
[INFO] ELK Target Platform ................................ SUCCESS [ 0.000 s]
[INFO] ELK Graph Model .................................... SUCCESS [ 0.548 s]
[INFO] ELK Layout Meta Data Language ...................... SUCCESS [ 16.769 s]
[INFO] ELK Core Components ................................ FAILURE [06:07 min]
[INFO] ELK Common Algorithms .............................. SKIPPED
[INFO] ELK Disconnected Components Compaction ............. SKIPPED
[INFO] ELK Layout Service Layer ........................... SKIPPED
[INFO] ELK Core Components (UI) ........................... SKIPPED
[INFO] ELK Debugging Utilities ............................ SKIPPED
[INFO] ELK DisCo Debugging Utilities ...................... SKIPPED
[INFO] ELK Force Layout Algorithm ......................... SKIPPED
[INFO] ELK Radial Layout Algorithm ........................ SKIPPED
[INFO] ELK Graphviz Dot Language Parser ................... SKIPPED
[INFO] ELK Layout Bridge for Graphviz ..................... SKIPPED
[INFO] ELK Layered Layout Algorithm ....................... SKIPPED
[INFO] ELK Mr. Tree Layout Algorithm ...................... SKIPPED
[INFO] ELK SPOrE .......................................... SKIPPED
[INFO] ELK Layout Connector for GMF ....................... SKIPPED
[INFO] ELK Layout Connector for Graphiti .................. SKIPPED
[INFO] ELK Layout Meta Data Language (UI Components) ...... SKIPPED
[INFO] ELK Graph JSON ..................................... SKIPPED
[INFO] plugins ............................................ SKIPPED
[INFO] features ........................................... SKIPPED
[INFO] org.eclipse.elk.feature ............................ SKIPPED
[INFO] org.eclipse.elk.algorithms.feature ................. SKIPPED
[INFO] org.eclipse.elk.sdk.feature ........................ SKIPPED
[INFO] org.eclipse.elk.gmf.feature ........................ SKIPPED
[INFO] org.eclipse.elk.graph.json.feature ................. SKIPPED
[INFO] org.eclipse.elk.graphiti.feature ................... SKIPPED
[INFO] org.eclipse.elk.graphviz.feature ................... SKIPPED
[INFO] org.eclipse.elk.ui.feature ......................... SKIPPED
[INFO] Eclipse Layout Kernel Repository ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:11 min
[INFO] Finished at: 2018-08-14T14:18:47+08:00
[INFO] Final Memory: 148M/1709M
[ERROR] Failed to execute goal org.eclipse.xtext:xtext-maven-plugin:2.10.0:generate (default) on project org.eclipse.elk.core: Execution failed due to a severe validation error. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <goals> -rf :org.eclipse.elk.core
FUDForum. Page generated in 0.06511 seconds
