Re: Xtext upgrade [message #1797616 is a reply to message #1793447] |
Fri, 02 November 2018 18:16 |
ABHAY GUPTA Messages: 1 Registered: November 2018 Location: SAN DIEGO |
I assume you are trying to upgrade to latest Xtext/Xtend release by keeping your current code / project intact. If yes, read ahead:
You will required to do changes in following files (in case below we are upgrading to 2.15.0 from 2.13.0):
1. parent/pom.xml
- <tycho-version>1.0.0</tycho-version>
- <xtextVersion>2.13.0</xtextVersion>
+ <tycho-version>1.2.0</tycho-version>
+ <xtextVersion>2.15.0</xtextVersion>
2. MANIFEST.MF
e.g. parent/mydsl/META-INF/MANIFEST.MF
- org.eclipse.xtext.xbase.lib;bundle-version="2.13.0",
- org.antlr.runtime,
+ org.eclipse.xtext.xbase.lib;bundle-version="2.14.0",
+ org.antlr.runtime;bundle-version="[3.2.0,3.2.1)",
org.eclipse.xtext.util,
org.eclipse.emf.common,
- org.eclipse.xtend.lib;bundle-version="2.13.0",
+ org.eclipse.xtend.lib;bundle-version="2.14.0",
3. parent/mydsl.target/target.target
update repository:
-<repository location="http://download.eclipse.org/releases/oxygen/201709271000"/>
+<repository location="http://download.eclipse.org/releases/2018-09/201809191002"/>
update xtext release version:
-<repository location="http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.13.0/"/>
+<repository location="http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.15.0/"/>
4. These files will be automatically updated once you build `mvn clean install`
parent/feature/feature.xml
parent/ui/plugin.xml_gen
Hope this helps!
FUDForum. Page generated in 0.02837 seconds
