Home » Eclipse Projects » Gemini » Needs help on migration from spring-dm to gemini blueprint(Needs help on migration from spring-dm to gemini blueprint)
Needs help on migration from spring-dm to gemini blueprint [message #1793389] Tue, 07 August 2018 10:11 Go to next message
Munish Gupta is currently offline Munish GuptaFriend
Hi All,
I was using KARAF 4.0.10 which installs spring 3.1.4 as boot feature. We were using spring for web module (spring-mvc) with spring-dm (spring-osgi-web).
Here is my example web.xml.
That is my web.xml Mvc Servlet
<context-param>
<param-name>contextClass</param-name>
<param-value>org.springframework.osgi.web.context.support.osgibundlexmlwebapplicationcontext</param-value>
</context-param>
<servlet>
<servlet-name>javorai-api</servlet-name>
<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
<init-param>
</init-param>
<load-on-startup>2</load-on-startup>
</servlet>
As we upgraded KARAF to 4.2.0, spring is upgraded to 5.0.4 and spring-dm does not support it anymore. it is deprecated now. based on internet search, I found the suggestion to move on to gemini blueprint as replacement of spring-dm. I have downloaded gemini-blueprint/IO, Core and extender module by configuring it as maven dependency.
Can you please guide on what should be changed in web.xml to move on to gemini blueprint as replacement of spring-dm?
Munish
Re: Needs help on migration from spring-dm to gemini blueprint [message #1793405 is a reply to message #1793389] Tue, 07 August 2018 15:55 Go to previous messageGo to next message
Florian Waibel is currently offline Florian WaibelFriend
Hi Munish,
maybe this migration guide can get you started: https://www.eclipse.org/gemini/blueprint/documentation/migration/
florian
Re: Needs help on migration from spring-dm to gemini blueprint [message #1793428 is a reply to message #1793405] Wed, 08 August 2018 07:07 Go to previous message
Hi Florian,
I had seen this document and this does not talk about web. osgibundlexmlwebapplicationcontext is the key class which i was not able to find any gemini-blueprint jar's after downloading.
Munish
Previous Topic:WAB not reacheable after deployment on Gemini WEB
Next Topic:Wrong handling of HTTP REDIRECT status by Eclipse gemini
Current Time: Fri Jul 10 11:18:10 GMT 2020
Powered by FUDForum. Page generated in 0.02235 seconds
