Home » Newcomers » Newcomers » [SOLVED] JVM terminated. Exit code=1(:can't open Eclipse after an abrupt hardware restart)
[SOLVED] JVM terminated. Exit code=1 [message #1793326] Sat, 04 August 2018 09:12 Go to next message
Harry Kar is currently offline Harry KarFriend
Eclipse Neon has worked flawlessly till an abrupt machine's restart (in which eclipse
application happens to be open)
after that, clicked on executable (eclipse) causes eclipse not start and emit that
error message :
/home/harrykar/Java8/eclipseJava/jre/bin/java
-jar /home/harrykar/Java8/eclipseJava/plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /home/harrykar/Java8/eclipseJava/eclipse
-name Eclipse
--launcher.library /home/harrykar/Java8/eclipseJava/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740/eclipse_1618.so
-startup /home/harrykar/Java8/eclipseJava/plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
--launcher.overrideVmargs
-exitdata 380035
-vm /home/harrykar/Java8/eclipseJava/jre/bin/java
-vmargs
first thing i control was the .ini file and in fact that resulted empty
After had copied the original eclipse.ini (from the installation .tar.gz file i had apart)
in $ECLIPSE_HOME directory and re-clicked the executable eclipse continue not
execute -as earlier and emit that (a little different) error message :
-Dosgi.requiredJavaVersion=1.8
-XX:+UseG1GC
-XX:+UseStringDeduplication
-Xms256m
-Xmx1024m
-jar /home/harrykar/Java8/eclipseJava//plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
-os linux
-ws gtk
-arch x86_64
-showsplash /home/harrykar/Java8/eclipseJava//plugins/org.eclipse.platform_4.6.3.v20170301-0400/splash.bmp
-name Eclipse
--launcher.library /home/harrykar/Java8/eclipseJava//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740/eclipse_1618.so
-startup /home/harrykar/Java8/eclipseJava//plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
--launcher.appendVmargs
-exitdata 350035
-product org.eclipse.epp.package.java.product
-vmargs
-XX:+UseG1GC
-Xms256m
-Xmx1024m
And now what? dunno what to do :(
TIA who contribute to solve
<<Update>>
in the above mentioned (original eclipse's distribution) configuration file eclipse.ini
1. delete line "-vmargs" and
2. add Your path to JDK after the last line with the format shown below
-vm
/home/harrykar/Java8/jdk1.8.0_172/bin
Now eclipse works flawlessly as before
PS: for completeness i use an old system with Ubuntu 10.04 (aka Lucid Lynx ) LTS that
can accept as latest eclipse release only Neon.3 Release (4.6.3) cause newer eclipse releases require newer releases of gtk library
Best Regards
Harry G.T. Kar
[Updated on: Tue, 07 August 2018 12:38]
Report message to a moderator
Re: [SOLVED] JVM terminated. Exit code=1 [message #1808868 is a reply to message #1793326] Wed, 03 July 2019 14:23 Go to previous messageGo to next message
Martin Kraitman is currently offline Martin KraitmanFriend
You save my work day.
Thank you :)
Re: [SOLVED] JVM terminated. Exit code=1 [message #1815802 is a reply to message #1793326] Fri, 11 October 2019 07:21 Go to previous messageGo to next message
Deepak Dixit is currently offline Deepak DixitFriend
It also save my day !.
Thank you for providing great solution !
Re: [SOLVED] JVM terminated. Exit code=1 [message #1818119 is a reply to message #1793326] Fri, 06 December 2019 09:28 Go to previous message
sambasiva kamatham is currently offline sambasiva kamathamFriend
Harry Kar wrote on Sat, 04 August 2018 09:12
error message :
-os linux
-ws gtk
-arch x86_64
-showsplash
-name Eclipse
-exitdata 380035
-vmargs
-XX:+UseG1GC
-Xms256m
-Xmx1024m
-os linux
-ws gtk
-arch x86_64
-name Eclipse
-exitdata 350035
-vmargs
-XX:+UseG1GC
-Xms256m
-Xmx1024m
<<Update>>
-vm
Previous Topic:Papyrus download
Next Topic:HelloWorld example doesn't run ( Error occurred during initialization of boot layer )
Current Time: Wed Apr 08 19:09:59 GMT 2020
Powered by FUDForum. Page generated in 0.03044 seconds
