Home » Modeling » TMF (Xtext) » Syntax for bitwise AND operator
Syntax for bitwise AND operator [message #1793116] Tue, 31 July 2018 10:52 Go to next message
shubhankar chowdhury is currently offline shubhankar chowdhuryFriend
Hi ,
I have an if condition in which i want to test all the condition and if all are TRUE then enter the condition.
but in xtend i dont know the syntax of bitwise or as in java it is '&'
Shubhankar
Re: Syntax for bitwise AND operator [message #1793117 is a reply to message #1793116] Tue, 31 July 2018 10:55 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
you can use
1.bitwiseOr(2)
1.bitwiseAnd(2)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Syntax for bitwise AND operator [message #1793122 is a reply to message #1793117] Tue, 31 July 2018 11:18 Go to previous messageGo to next message
both my condition are boolean condition. when i try to implement
(booleanValue1).bitwiseAnd(booleanVlaue2), I am geting the error as:
The method bitwiseAnd(boolean) is undefined for the type boolean
Do I need to import any package?
[Updated on: Tue, 31 July 2018 11:26]
Report message to a moderator
Re: Syntax for bitwise AND operator [message #1793129 is a reply to message #1793122] Tue, 31 July 2018 12:25 Go to previous messageGo to next message
bytewise and for java ???
what exactly should that do different from a normal &&
[Updated on: Tue, 31 July 2018 12:25]
Re: Syntax for bitwise AND operator [message #1793130 is a reply to message #1793129] Tue, 31 July 2018 12:31 Go to previous messageGo to next message
of course you can do something like
java util
package a;
import org.eclipse.xtext.xbase.lib.Inline;
import org.eclipse.xtext.xbase.lib.Pure;
public class Lala {
	@Pure
	@Inline(value="($1 & $2)", constantExpression=true)
	public static boolean bytewiseAnd(boolean a, boolean b) {
		return a&b;
	@Pure
	@Inline(value="($1 | $2)", constantExpression=true)
	public static boolean bytewiseOr(boolean a, boolean b) {
		return a|b;
xtend code
package a
import static extension a.Lala.*
class Demo {
	def main() {
		val x = 1.bitwiseOr(2)
		val y = 1.bitwiseAnd(2)
		val a = true.bytewiseAnd(false)
		val a2 = true.bytewiseOr(false)
Re: Syntax for bitwise AND operator [message #1794935 is a reply to message #1793129] Tue, 11 September 2018 10:16 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
Christian Dietrich wrote on Tue, 31 July 2018 12:25
& and | as boolean operators are eager as opposed to && and || which are lazy.
Previous Topic:XText importing a specific file extension
Next Topic:Operator == with null operand
Current Time: Mon Oct 03 06:29:33 GMT 2022
Powered by FUDForum. Page generated in 0.01728 seconds
