Home » Eclipse Projects » Virgo » Multiple spring deployments on Virgo 3.7.2(Multiple spring deployments on Virgo 3.7.2)
Multiple spring deployments on Virgo 3.7.2 [message #1792911] |
Wed, 25 July 2018 15:48  |
Jesus Martinez Messages: 4 Registered: July 2018 |
I'm trying to start migrating to Eclipse Virgo 3.7.2 to move to Spring 4.3.9.
I'm getting a stream of Uses violation errors that we didn't have before with 3.6.4. I had to make some adjustments to migrate the spring schemas and remove the springframework libd which seems to be gone now but nothing to explain the following:
[2018-07-23 19:20:12.040] fs-watcher <DE0002E> Installation of plan 'multi-artifact.plan' version '1.0.0' failed. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'multi-artifact.plan-1-org.geppetto.frontend' at version '0.3.9': Cannot resolve: multi-artifact.plan-1-org.geppetto.frontend
Resolver report:
An Import-Package could not be resolved. Resolver error data <Import-Package: org.springframework.web.servlet; version="0.0.0">. Caused by missing constraint in bundle <multi-artifact.plan-1-org.geppetto.frontend_0.3.9>
constraint: <Import-Package: org.springframework.web.servlet; version="0.0.0">
An Import-Package could not be resolved. Resolver error data <Import-Package: org.geppetto.frontend.admin; version="0.0.0">. Caused by missing constraint in bundle <multi-artifact.plan-1-synthetic.context_1.0.0>
constraint: <Import-Package: org.geppetto.frontend.admin; version="0.0.0"> constrained to bundle <multi-artifact.plan-1-org.geppetto.frontend> constrained bundle version range "[0.3.9,0.3.9]"
with attributes {module_scope=multi-artifact.plan-1}
Uses violation: <Import-Package: org.springframework.http.converter.xml; version="[4.3.9.RELEASE,4.3.9.RELEASE]"> in bundle <org.springframework.webmvc_4.3.9.RELEASE[1532366399144]>
Resolver reported uses conflict for import
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:359)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:185)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:140)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:225)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeployerFileSystemListener.java:237)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:88)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:380)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:289)
at org.eclipse.virgo.nano.deployer.hot.WatchTask.run(WatchTask.java:49)
at java.lang.Thread.run(Thread.java:748)
[2018-07-23 19:20:12.041] fs-watcher <DE0003E> Install failed for bundle 'multi-artifact.plan-1-org.geppetto.model' version '0.3.9'.
[2018-07-23 19:20:12.042] fs-watcher <DE0003E> Install failed for bundle 'multi-artifact.plan-1-org.geppetto.core' version '0.3.9'.
[2018-07-23 19:20:12.043] fs-watcher <DE0003E> Install failed for bundle 'multi-artifact.plan-1-org.geppetto.model.neuroml' version '0.3.9'.
[2018-07-23 19:20:12.044] fs-watcher <DE0003E> Install failed for bundle 'multi-artifact.plan-1-org.geppetto.simulation' version '0.3.9'.
[2018-07-23 19:20:12.046] fs-watcher <DE0003E> Install failed for bundle 'multi-artifact.plan-1-org.geppetto.frontend' version '0.3.9'.
[2018-07-23 19:20:12.047] fs-watcher <DE0003E> Install failed for plan 'multi-artifact.plan' version '1.0.0'.
[2018-07-23 19:20:12.048] fs-watcher <DE0500E> Unable to install application from URI 'file:/home/walrus/code/virgo-tomcat-server-3.7.2.RELEASE/pickup/geppetto.plan'. Cannot satisfy constraints for bundle 'multi-artifact.plan-1-org.geppetto.frontend' version '0.3.9'. Cannot resolve: multi-artifact.plan-1-org.geppetto.frontend
Resolver report:
Resolver report:
[2018-07-23 19:20:12.053] fs-watcher <HD0002E> Hot deploy failed for file 'geppetto.plan'. org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Dependency satisfaction failed
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:362)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'multi-artifact.plan-1-org.geppetto.frontend' at version '0.3.9': Cannot resolve: multi-artifact.plan-1-org.geppetto.frontend
Resolver report:
... 10 common frames omitted
Our project is maven based, and in the pom.xml file we are using the following dependencies:
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-core</artifactId>
<version>${spring.version}</version>
</dependency>
<dependency>
<artifactId>spring-aspects</artifactId>
</dependency>
<dependency>
<artifactId>spring-context</artifactId>
</dependency>
<dependency>
<artifactId>spring-context-support</artifactId>
</dependency>
<dependency>
<artifactId>spring-beans</artifactId>
</dependency>
<dependency>
<artifactId>spring-test</artifactId>
</dependency>
<dependency>
<artifactId>spring-webmvc</artifactId>
</dependency>
<dependency>
<artifactId>spring-web</artifactId>
</dependency>
<dependency>
Where the spring.version = 4.3.9
Virgo 3.7.2 also comes with springframework 4.3.9 dependencies in repository/ext folder.
The pickpup plan I'm using looks like this:
The artifact that's causing the problem is the last one, org.geppetto.frontend. If I remove it from the plan, and then go to http://localhost:8080/admin/content/artifacts and manually deploy the artifact from there, I don't get the error.
Any ideas on what's going on are much appreciated !
Re: Multiple spring deployments on Virgo 3.7.2 [message #1793009 is a reply to message #1792970] |
Fri, 27 July 2018 12:58   |
Thanks for the feedback.
I tried making my plan not scope but it didn't work, I still get the same result.
This is how my plan looks now.
<plan name="multi-artifact.plan" version="1.0.0" scoped="false" atomic="true"
xmlns="http://www.springsource.org/schema/dm-server/plan"
xsi:schemaLocation="
http://www.springsource.org/schema/dm-server/plan/springsource-dm-server-plan.xsd">
<artifact type="bundle" name="org.geppetto.model" version="0.3.9"/>
<artifact type="bundle" name="org.geppetto.core" version="0.3.9"/>
<artifact type="bundle" name="org.geppetto.model.neuroml" version="0.3.9"/>
<artifact type="bundle" name="org.geppetto.simulation" version="0.3.9"/>
<artifact type="bundle" name="org.geppetto.frontend" version="0.3.9"/>
</plan>
I double checked and all the bundles are using spring 4.3.9 . The spring bundles that are in virgo's repostitory folder "usr" are also 4.3.9, same version than the ones in virgo's repository "ext" folder, except that the ones in "usr" are not OSGI bundles and come directly from maven.
Looking at the Manifest file for the org.geppetto.frontend bundle, I do see some references to spring packages from the export-package section.
Should these not be there?
Manifest-Version: 1.0
Bundle-SymbolicName: org.geppetto.frontend
Import-Library: org.springframework.spring;version="4.3.9.RELEASE"
Archiver-Version: Plexus Archiver
Built-By: walrus
Bnd-LastModified: 1532694315220
Bundle-ManifestVersion: 2
Import-Package: com.fasterxml.jackson.core;version="[2.1,3)",com.faste
rxml.jackson.core.type;version="[2.1,3)",com.fasterxml.jackson.databi
nd;version="[2.1,3)",com.google.gson;version="[2.2,3)",com.google.gso
n.annotations;version="[2.2,3)",com.google.gson.reflect;version="[2.2
,3)",javax.servlet;version="[3.1,4)",javax.servlet.http;version="[3.1
,4)",javax.websocket,javax.websocket.server,net.sf.cglib.beans;versio
n="[2.2,3)",net.sf.cglib.core;version="[2.2,3)",net.sf.cglib.proxy;ve
rsion="[2.2,3)",net.sf.cglib.reflect;version="[2.2,3)",net.sf.cglib.t
ransform;version="[2.2,3)",net.sf.cglib.util;version="[2.2,3)",org.ap
ache.commons.io;version="[1.4,2)",org.apache.commons.logging;version=
"[1.2,2)",org.apache.shiro;version="[1.2,2)",org.apache.shiro.authc;v
ersion="[1.2,2)",org.apache.shiro.realm;version="[1.2,2)",org.apache.
shiro.subject;version="[1.2,2)",org.apache.shiro.web.env;version="[1.
2,2)",org.apache.shiro.web.servlet;version="[1.2,2)",org.eclipse.emf.
common.util,org.eclipse.emf.ecore,org.eclipse.emf.ecore.util,org.ecli
pse.virgo.web.dm;version="2.1.1.RELEASE",org.geppetto.core.auth;versi
on="[0.3,1)",org.geppetto.core.beans;version="[0.3,1)",org.geppetto.c
ore.common;version="[0.3,1)",org.geppetto.core.data;version="[0.3,1)"
,org.geppetto.core.data.model;version="[0.3,1)",org.geppetto.core.dat
asources;version="[0.3,1)",org.geppetto.core.manager;version="[0.3,1)
",org.geppetto.core.model;version="[0.3,1)",org.geppetto.core.s3;vers
ion="[0.3,1)",org.geppetto.core.services.registry;version="[0.3,1)",o
rg.geppetto.core.simulation;version="[0.3,1)",org.geppetto.core.utili
ties;version="[0.3,1)",org.geppetto.model;version="[0.3,1)",org.geppe
tto.model.datasources;version="[0.3,1)",org.geppetto.model.util;versi
on="[0.3,1)",org.geppetto.simulation;version="[0.3,1)",org.geppetto.s
imulation.manager;version="[0.3,1)",org.geppetto.simulation.visitor;v
ersion="[0.3,1)",org.osgi.framework;version="[1.7,2)",org.springframe
work.beans.factory.annotation,org.springframework.beans.factory.confi
g,org.springframework.context,org.springframework.core.annotation,org
.springframework.core.io,org.springframework.http,org.springframework
.http.converter,org.springframework.stereotype,org.springframework.ui
,org.springframework.util,org.springframework.web.bind.annotation,org
.springframework.web.context,org.springframework.web.context.support
Tool: Bnd-1.50.0
Export-Package: org.geppetto.frontend;uses:="org.springframework.conte
xt";version="0.3.9",org.geppetto.frontend.admin;uses:="org.apache.shi
ro,org.geppetto.core.common,org.apache.commons.logging,org.geppetto.c
ore.manager,org.springframework.stereotype,org.geppetto.core.data.mod
el,org.springframework.web.bind.annotation,org.geppetto.core.data,org
.geppetto.core.s3,org.springframework.beans.factory.annotation,org.ap
ache.shiro.subject";version="0.3.9",org.geppetto.frontend.controllers
;uses:="org.springframework.ui,org.apache.shiro,javax.servlet.http,or
g.geppetto.core.utilities,org.geppetto.core.common,javax.servlet,org.
apache.commons.logging,org.geppetto.core.manager,org.geppetto.fronten
d.tests,org.springframework.stereotype,org.geppetto.core.auth,org.spr
ingframework.web.bind.annotation,org.geppetto.core.data.model,org.gep
petto.core.data,org.springframework.beans.factory.annotation,com.goog
le.gson,org.apache.shiro.subject,org.osgi.framework,org.geppetto.mode
l.util,org.geppetto.core.services.registry,com.fasterxml.jackson.core
,org.apache.commons.io,org.geppetto.model,org.geppetto.core.simulatio
n,org.geppetto.frontend,org.geppetto.model.datasources,com.fasterxml.
jackson.databind,org.eclipse.emf.ecore,org.geppetto.core.beans,org.ge
ppetto.core.model,org.geppetto.simulation.manager,com.fasterxml.jacks
on.core.type,org.geppetto.core.datasources,org.geppetto.frontend.mess
ages,javax.websocket,org.apache.shiro.authc,org.apache.shiro.realm,or
g.springframework.http,org.springframework.http.converter,org.springf
ramework.util,org.springframework.web.context,org.springframework.cor
e.annotation,javax.websocket.server,org.springframework.beans.factory
.config,com.google.gson.reflect,org.geppetto.frontend.messaging,org.e
clipse.emf.common.util,org.springframework.web.context.support";versi
on="0.3.9",org.geppetto.frontend.dashboard.service;uses:="org.geppett
o.core.utilities,org.springframework.core.io,org.geppetto.core.beans,
org.geppetto.core.common,org.geppetto.core.manager,org.springframewor
k.stereotype,org.geppetto.core.data.model,org.springframework.web.bin
d.annotation,org.geppetto.core.data,org.springframework.beans.factory
.annotation,org.eclipse.emf.ecore,org.geppetto.model.util,org.geppett
o.core.model,org.geppetto.model,org.geppetto.simulation.visitor,org.e
clipse.emf.ecore.util,org.apache.shiro,org.apache.commons.logging,org
.apache.shiro.subject";version="0.3.9",org.geppetto.frontend.messages
;uses:="org.geppetto.frontend,com.google.gson";version="0.3.9",org.ge
ppetto.frontend.messaging;uses:="org.apache.commons.logging,org.geppe
tto.frontend.messages,javax.websocket,com.google.gson";version="0.3.9
",org.geppetto.frontend.tests;uses:="com.google.gson.annotations";ver
sion="0.3.9"
Bundle-Name: frontend
Bundle-Version: 0.3.9
Bundle-ClassPath: .,WEB-INF/classes
Web-ContextPath: org.geppetto.frontend
Created-By: Apache Maven Bundle Plugin
Build-Jdk: 1.8.0_171
Re: Multiple spring deployments on Virgo 3.7.2 [message #1794206 is a reply to message #1793395] |
Mon, 27 August 2018 13:45   |
I finally fixed this bug. The problem was a package ("javax.xml.bind") with different version numbers been used by two bundles.
To fix it I removed the following code from the file "virgo/configuration/java-server.profile"
javax.xml.bind,\
javax.xml.bind;version="2.0",\
javax.xml.bind.annotation,\
javax.xml.bind.annotation;version="2.0",\
javax.xml.bind.annotation.adapters,\
javax.xml.bind.annotation.adapters;version="2.0",\
javax.xml.bind.attachment,\
javax.xml.bind.attachment;version="2.0",\
javax.xml.bind.helpers,\
javax.xml.bind.helpers;version="2.0",\
javax.xml.bind.util,\
javax.xml.bind.util;version="2.0",\
Removing those lines removes the conflict between "javax.xml.bind" versions.
Not sure if removing those lines would have other undesired consequences. What's the purpose of having those lines in the java-server.profile?
Current Time: Thu Mar 04 04:56:09 GMT 2021
Powered by FUDForum. Page generated in 0.02291 seconds
